-   -   Need help wiring up a new thermostat (http://www.diychatroom.com/f17/need-help-wiring-up-new-thermostat-169987/)
lmholmes11 01-24-2013 09:08 AM
7 Attachment(s)
Hello.
I have an old Friedrich Thermostat (still uses mercury) running my heat pump furnace. I bought a new Honeywell thermostat and im confused on where to put the old black wire, along with the W1 and W2. In the instructions it says that if I have both a Y1 and W2 and W3 wires that i should ask for help.
Here are the wires my old, existing thermostat has:
F- White wire
Y-Yellow wire
W1- Green
W2- Blue
O-Orange
R-Red
#5- Black. (New thermostat does not have a #5, whats this wire for??)
NEW thermostat terminals:
B
O
G
Y
W/Aux
R
Rc (R and Rc terminals are jumped)
In the instructions it says that the "W/Aux" terminal can be used for W, W1, or W2. But I cant put BOTH of my w1 and w2 wires in that terminal can i?
Thanks everyone for looking and for the help.
JJboy 01-24-2013 10:31 AM
You need a 2 stage heat thermostat
Sent from my iPhone using DIY Forum
lmholmes11 01-24-2013 11:11 PM
7 Attachment(s)
Ok thanks.
On the package it says "Works with heat pumps w/ Auxillary" so I figured this meant it was a two stage thermostat.
sktn77a 01-26-2013 01:31 PM
Yes, it should work if its designed to run a heat pump with auxilliary heat. Don't the instructions that came with the stat give any insights (this is a pretty standard set up)? As to the black wire, no idea. :(
lmholmes11 01-26-2013 03:52 PM
7 Attachment(s)
Yeah the instructions came with a diagram and all of the different possible wire/terminal combinations that may be used with different manufacturers...but I have both a w1 and w2 wires and only one terminal. Unless I can just join w1 and w2 together and put them in the same terminal.
hvactech126 01-26-2013 04:15 PM
Does the old thermostat have a emergency heat function? Does the new thermostat have an E terminal. What is the model of the old and new thermostat?
lmholmes11 01-27-2013 09:57 AM
7 Attachment(s)
Yes the old one has emergency heat setting. Old thermostat is a friedrich. Not sure of the model. New stat is a Honeywell RTH2410B.
Does not have an E terminal but it does have a terminal that says "not used."
Missouri Bound 01-27-2013 10:44 AM
Thermostat wiring colors and furnace terminal designations repair.
Will this help you?
beenthere 01-27-2013 11:30 AM
Need to see where the W1 and W2 wires go in your air handler. That stat is not designed to control stage aux heat.
sktn77a 01-30-2013 09:46 PM
From the link above:
"On a heat pump system the compressor ("Y" terminal) is activated for both heating and cooling the only difference is that to switch to cooling the O terminal is activated to reverse the outdoor unit"
I think the thermostat will work with your system but you need to post the exact model number to figure out the wiring and, as Been says, check which wires go where in your furnace (you can't always go by the color). I think I know how this would work, but I'm reluctant to tell you something that could damage your compressor!
