Need Help Wiring Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 11:55 AM   #1
need help wiring thermostat
need help wiring Honeywell RHT7500 thermostat to a Goodman GPH1549M package unit heatpump: w/ 2 stage heat and air
THERMOSTAT=C, G, Y, O/B, R/C, R, Aux, E, L.
HEATPUMP=W, Br, O, Bl, R, Purple, G, Y,
litt1966 is offline   Reply With Quote
Old 11-01-2010, 04:46 AM   #2
An old Tradesmen
Rewards Points: 7,770
Always helps if you post the terminal designations of both the thermostat, and the unit/heat pump.
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
