Need Help Wiring A Honeywell VisionPro TH8110U - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 10:20 PM   #1
Need help wiring a Honeywell VisionPro TH8110U
In the process of changing my thermostat to a VisionPro TH8100U. My system is a 1 heat, 1 cool heat pump system and the fan has 3 different speed settings (hi, med, low). The current wiring coming from the heat pump has 6 wires (Red, Black (120v), Blue, Brown, Orange and Yellow) and are connected to the same coloured wires coming off the original thermostat. From what I can tell from the wiring diagram on the heat pump - red, black, blue and brown go to the motor and yellow and orange go to the valve.
My question is what terminals do I hook these 6 wires up to the new stat?
Thanks for any help
stevie347 is offline   Reply With Quote
Old 07-19-2011, 10:45 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
what do you use for back up heat? What were the wires hooked to on the old stat? What model was the old stat? NO thermostat wires should be 120V! Fan has 3 speeds? Were they selectable from the old stat or already setup for heating vs cooling? Pictures will help tremendously!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-19-2011, 11:14 PM   #3
Rewards Points: 6,652
Doesn't anyone read the directions that come with the thermostat anymore. As for the OP, honeywell.com has a help walk through on their website, along with the manual. You will need the installer directions to finish the install, because you just can't hook this toy up and let go, there is some programming to do, to make it work properly.
Old 07-20-2011, 05:28 AM   #4
An old Tradesmen
Rewards Points: 6,112
Post the brand and model number of your heat pump.
Old 07-20-2011, 07:03 PM   #5
Sorry guys, turns out I have a fan coil, not a heat pump....which is why im not allowed around tools lol
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 07:52 PM
wiring diagram of Honeywell VisionPro IAQ ochir Electrical 1 03-27-2011 10:02 PM
Honeywell VisionPro IAQ YTH9421C1002 Wiring Help jond777 HVAC 0 11-22-2010 10:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
