Need Help Wiring Five Wires To Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 08:46 AM   #1
need help wiring five wires to capacitor
I have an old Concept high efficiency a/c split system. The tech tells me the compressor is on its way out. I removed the dual capacitor for testing but forgot to mark the wires. there are five wires going to the capacitor. Red, brown, yellow and two light gauge blue wires that come from a black round cylinder that says "110W to 260W Single Phase - something thru 5 HP".
I'm thinking the three wires, yellow, red and brown are wired Yellow to HERM, Red to Common and Brown to Fan. That leaves the two light gauge blue wires coming from the black round cylinder. Any idea where these two light gauge blue wires go?
DavidAnderson is offline   Reply With Quote
Old 06-22-2012, 12:24 PM   #2
Common and herm.
Old 06-22-2012, 01:38 PM   #3
Thank you very much, that did the trick! Now, the A/C fan is blowing warm air outside and cold air is flowing inside, however I think the blower motor is not working. I have a Carrier 8000 Weathermaker heater in the closet in the garage. Where is the blower motor located?
Old 06-22-2012, 01:40 PM   #4
JJboy's Avatar
At the coil, inside of your house or attic
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-22-2012, 02:23 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
in that furnace in the garage.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-22-2012, 03:30 PM   #6
Under the furnace section sits the Evaporator coil, then under the Evaporator coil is a large metal box 38" wide by 36" deep by 18" tall and sits directly on the concrete floor. is that where the blower motor is located?
Old 06-22-2012, 04:22 PM   #7
Sounds like you have a down flow furnace. The blower will be in the upper half of the furnace.
Old 06-22-2012, 05:09 PM   #8
Just take off the doors and be done with it. Take a picture and post it if you're still uncertain. If it looks like this than it's an upflow.
Thanks.
Old 06-22-2012, 06:10 PM   #9
I'm thinking the large box on the floor houses the blower. what do you think?
Old 06-22-2012, 06:49 PM   #10
JJboy's Avatar
Open it....you will see the blower motor wheel.....
Trane XL13i specs and wiring diagram jaraasch HVAC 5 06-03-2014 01:56 PM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 03:51 PM
Wiring a replacement blower motor bodtchboy HVAC 17 08-11-2011 10:05 PM
3 to 4 wire condensor fan wiring nuckifuts HVAC 3 07-27-2011 12:11 AM
Please help with wiring adamwsh HVAC 4 07-13-2010 05:47 PM
