Need Help Understanding Honeywell Diagram - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 01:27 AM   #1
Need help understanding honeywell diagram
I am wiring a 2 wire baseboard thermostat into an existing 4 wire. I think it is 4 wire because there are 2 red and 2 black wires going into the old thermostat.
I am confused and do not understand the honeywell diagram.
Can someone help. here is the link to the 4 wire diagram.
http://customer.honeywell.com/TechLi...0s/69-1855.pdf
I have 2 red and 2 black in the junction box. Any help is appreciated.
kingflow is offline   Reply With Quote
Old 11-23-2009, 04:14 AM   #2
There's a picture of the four wire installation right in the directions. What are you confused about? There are two wires coming from the source(red/black) and two wires going to the heater(the other red/black). In the diagram the lighter wire will be the red and the black is the black. Is the outer jacket of your wires red?
jerryh3 is offline   Reply With Quote
Old 11-24-2009, 09:39 PM   #3
hi jerry
Thanks for your reply. The problem is this. the current old thermostat has 4 wires hooked up. 2 red and 2 black go into the thermostat.
This is where I get confused. the new thermostat is a 2 wire.
the old thermostat has 2 red on top and 2 black on bottom. one red on top is connected to a red in the wall. the other red on top is connected to a black in the wall. on the bottom of thermostat one black is connected to a red in the wall and another black on the bottom is connected to a black in the wall.
I hope this helps you understand why I would be confused.
Old 11-25-2009, 04:16 AM   #4
Can you post a picture. Look at the diagram again. What you are describing is exactly what is depicted in the installation manual.
Thermostat for electric baseboard heat 4 wire to 2 wire rossl56 HVAC 12 11-12-2014 04:10 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
