Need Help With A Thermostat Install - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 09:40 AM   #1
Need help with a thermostat install
OK we just moved in and the cooling worked fine. Now we went to turn the heat on and nothing. Everything worked when we looked at the place but had them change the thermostat. It was some old junker. Nordyne E2EB-012ha electric Goodman CPLE36-1c heat pump Hunter Thermostat Nothing is marked I have the nordyne open so I can check wires. Could someone please help it's 60 in here today.
dar748 is offline   Reply With Quote
Old 11-06-2010, 10:10 AM   #2
Rewards Points: 1,578
Follow the instructions that came with the thermostat: identify the letter/number of the terminal in the old thermostat and align that with recommendations from owner's manual for the new ones. Wire color is not always reliable.
bob22 is offline   Reply With Quote
Old 11-06-2010, 10:16 AM   #3
I do not change it, and have no idea what was where. At the thermostat i have Red RC RH jumped Yellow Y1 White W2 Orange C blue O Brown E Now at the furnace blue is not connected to anything.
Old 11-06-2010, 02:31 PM   #4
An old Tradesmen
Rewards Points: 6,852
Look in the outdoor unit. And see if the orange wire is connected to the O terminal out there. if so. guess where it belongs connected on you thermostat.
Good chance. You need the Blue connected to C on the stat, and C in the indoor unit.
Thermostat wiring question sob HVAC 11 10-21-2009 10:31 AM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 10:46 AM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
