Old 02-25-2007, 04:38 PM   #1
Need help with thermostat
Hello,
I have central heat and air condition. I currently have a mercury thermostat and I would like to convert to a programmable digital thermostat. But when I look at the thermostats that are available at the local stores, I am not for sure if it is the right one that I need. For example, I do not know if my system is single pump, or 2 stage pump, or even a pump at all. Also, there is an “EM. HT.” selection on my mercury thermostat and I do not know what that is used for. All I know is that it is central heat and air and I have a large machine in a closet in the house and I have a large machine outside. If I cut on either the heat or air, the machine in the house comes on. But I was told the machine outside is for AC. Can you guys please help me figure out what the heck kind of system I have so I know how to it works and what to put for it.
Thanks…
teeforb is offline   Reply With Quote
Old 02-25-2007, 10:12 PM   #2
Since you admitingly have little or no knowledge, in this it would be best to call on a local HVAC contractor to handel this repair.
harleyrider is offline   Reply With Quote
Old 02-25-2007, 11:44 PM   #3
Well, I have already bought a system and installed it. I bought the Honeywell 7500D. I guess I installed it right. It seems to work.
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 03:36 PM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 02:02 PM
Thermostat question ctown HVAC 7 12-05-2006 04:46 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
