Need Help Testing RTU Transformer (Pics) - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 02:19 PM   #1
Rewards Points: 40
SOLVED Need help testing RTU transformer (Pics)
Hi there,
The problem: I have no power to a 1H/1C thermostat. I have checked the whole wire for a splice, short, etc and the wire is good. I have tested power with a multimeter to the red power connection and the green blower connection, and have manually spliced the power and blower wires to at least kick on the fan. Even with it spliced, it will not turn on the fan - The unit will not kick on.
What I have done: I have tested power on the roof top unit (It is a small carrier model) from the power in to the contactor and I get 120v on both sides of the contactor. In addition, I can manually kick on the compressor on this contactor (not going to do me much good as it is -22 celcius out). What I wanted to do was test the high and low side of the 24v transformer, which usually is not hard for me to do on the Lennox models we have here (90% are Lennox) but I'm unsure about this carrier, as it is different.
The carrier model is a 48-SS 1 heat 1 cool. Link HERE
If I understand correctly, there is a fault LED (seen in one of the pictures) - There is no flashes, but I am not sure if I have to manually start that LED somehow to test that.
What I need an answer to:
  1. Am I correct in starting my search at the transformer?
  2. Based on the pictures below... What the heck do I do???
Thanks guys!
Cam
CamaLamaDD is offline   Reply With Quote
Old 11-29-2012, 04:55 PM   #2
An old Tradesmen
Rewards Points: 6,870
Check for 24 volts at R and C on the board.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (11-29-2012)
Old 11-29-2012, 08:06 PM   #3
Rewards Points: 582
Originally Posted by CamaLamaDD View Post
Hi there,
Thanks guys!
Cam
yes check for 120 volt going to transformer supply side then check for 24 volts on secondary side.... if you have the proper voltage on both sides of transformer..check for inline fuses..ben sr
Old 11-30-2012, 09:31 AM   #4
Rewards Points: 40
Turns out it was a fuse, I must have shorted the red wire when I took the thermostat off the other day. Thanks Ben.
The Following User Says Thank You to CamaLamaDD For This Useful Post:
ben's plumbing (11-30-2012)
Locating Doorbell Transformer RodC Electrical 13 11-13-2012 06:00 PM
Trane XE 80 burn my 120 to 24V transformer berr3555 HVAC 6 09-28-2012 08:23 AM
Gas Pressure Testing With Manometer a_lost_shadow Plumbing 4 07-01-2012 04:36 PM
Lennox P-8-9490 Transformer Burned Out Harbicide HVAC 2 07-04-2011 04:57 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
