Need HELP With "Synder General" Wiring - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 07:32 PM   #16
newtech's Avatar
Rewards Points: 164
Hey, just follow the wire's. I know it look's Mickey Mouse threw up on it but it's not that bad to follow
newtech is offline   Reply With Quote
Old 04-23-2009, 08:00 PM   #17
finally found a wiring dig. on the AC until in the attic, however i still cannot find a model number on it. Now my problem is I can read the dig. just fine I know where the wires coming out of the unit go inside of the unit. But I still do not know which wires from the control line need to be connected to which wires from the unit. here is a photo of the dig. I found so can someone please just tell me how to connect them.
Mcgver is offline   Reply With Quote
Old 04-28-2009, 11:36 AM   #18
Any help?
Old 04-28-2009, 05:47 PM   #19
newtech's Avatar
Rewards Points: 164
Post the model of the t-stat you have. Also let me know what color is connected to which terminal on the t-stat. r=?,w=?,y=?,g=?,o=? and a w2 if you have one. Also on your last post see note 4. Is there any more info you can give? Model number?
Old 04-29-2009, 08:31 AM   #20
Sadly I can not find any model numbers on that unit. the only numbers I can find are on the outside unit.
Now for the t.sat it is a Janitrol HPT 18-60
Here is a pic of the inside of it
Old 04-29-2009, 04:54 PM   #21
newtech's Avatar
Rewards Points: 164
You are really gunna make me think after a hard day aren't you Let me draw it up and I will get back to you.
Old 04-29-2009, 05:57 PM   #22
newtech's Avatar
Rewards Points: 164
Ok, from what I can tell here is the wire diagram, , the color's on the indoor unit don't match to the print I got soo don't fault me 1. yellow from the t-stat to yellow on the out side unit. 2. Green from the t-stat to green on the inside unit( ya I know u don't have a green ). 3. Red from t-stat to pink inside and to red out side unit(ya i know u don't have a pink). 4 Orange from t-stat to orange on outside unit. 5. White on t-stat to white on inside unit and to white on outside unit. 6. Blue from t-stat to brown inside unit. 7. Brown from t-stat to brown outside unit. This is the best I can come up from with the info provided.
Old 04-30-2009, 03:18 PM   #23
Thank you I will get up there and see what happens. Will let you know
Old 04-30-2009, 07:17 PM   #24
Well Tried it again and still no luck so it looks like it is time to call in the pros
Old 05-01-2009, 05:45 PM   #25
newtech's Avatar
Rewards Points: 164
Well I tried with what was given. Sorry it didn't work out. The pics on the air handler didn't match the photo that you uploaded. Without being there with a meter and tracing the wires, well hard to tell
Old 05-02-2009, 10:23 AM   #26
Yeah I kinda figured that was what was gonna happen, I apperactice all the help you gave.
Old 05-08-2009, 06:45 PM   #27
newtech's Avatar
Rewards Points: 164
Did you ever get it fixed? If so what was the problem?
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
