Need HELP With "Synder General" Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 01:43 PM   #1
Question
Need HELP with "Synder General" wiring
Ok heres the deal I just moved into a famliy house, that has a old synder general heating and cooling system (Model numbers Outside unit YC024G, Inside unit DCYPA018/024) well it was working fine up until a month ago when a squriell got in to the attic and chewed up the control wires well now I am stuck tring to figure out how to wire it back up.
Here are some photos that show what I have to deal with.
In the photo you will see two brown lines at the left of the photo the top one runs to the outside unit, the bottom one runs to the Thermosat control panel in the hall.
the control line has the following wires, yellow, white, orange, brown, red, blue, green and black. On the indoor unit I have a Brown, white, red, yellow and gray.
C. = control line. Now as you can see from the above photos there is still a C. blue connected to the brown wire, and C. white to the white
This is a shot of the wiring on the outside unit they are connected as follows. C. yellow to yellow, C. white to white, C. orange to orange, C. brown to Looks Tan, C. red to red with the green, black, and blue connected to nothing.
If you can make any sense of this please give me a hand.
Mcgver is offline   Reply With Quote
Old 04-14-2009, 02:15 PM   #2
HVAC / Plumbing
It's hard for me to see the attic photos. You should be able just wire all the colors back together. The only problem is if you have 2 wires the same color. If so, you'll have to determine where they go. You may also have a fried transformer
kenmac is offline   Reply With Quote
Old 04-14-2009, 02:53 PM   #3
Well thats the problem cause the colors dont match up.
Old 04-14-2009, 03:42 PM   #4
newtech's Avatar
Rewards Points: 164
Do either of the units have a schematic in them? If so take a pic and post it so we can better help you out. I don't have one on the units that you listed. (Snyder General) Makes me everytime I hear that name. I have a call into the factory for a schematic(don't hold you breath) hopefully someone here has the info and get it to you sooner.
newtech is offline   Reply With Quote
Old 04-14-2009, 04:55 PM   #5
Saftety First!
Rewards Points: 77
Wow! Looks pretty messed up Mike
But if I know you, you'll get it working one way or another.
loyal is offline   Reply With Quote
Old 04-14-2009, 05:26 PM   #6
Go with the lengths of undamaged wires. It's unlikely that he chewed two identical colored wires the same distance from the cable sleeve.
Old 04-14-2009, 09:32 PM   #7
HVAC / Plumbing
Hard for me to tell.. Is there 2 wires left unconnected or ??. If the t.stat still operates you could turn it to different settings & check with v.m which un connected wire/wires are hot. Can you look inside the cabinet & tell where those un connected wires come from ?
Old 04-15-2009, 03:27 PM   #8
neither unit have any diagrams on them (too old I guess), the T.Sat is useless right now cause the Control wires are the ones we are dealing with here. If you look at the last photo the two yellow Control line wires are together, the two orange wires are twisted together but not capped. There are two C. Whites connected to the White. Also a c.blue connected to the brown line with whats left of a cap but not sure if anything else was supposed to be there also.
Old 04-17-2009, 04:01 PM   #9
newtech's Avatar
Rewards Points: 164
Schematic
Here is the schematic for the yc018/024 with a typical air handler with electric heat. The number you gave dcypa018/024 is for the coil not the air handler. I need the number on the air handler if this doesn't help. Let me know. Thanks
Old 04-17-2009, 07:13 PM   #10
Thanks I'll see what I can do
Old 04-21-2009, 02:49 PM   #11
newtech's Avatar
Rewards Points: 164
Did you get it fixed yet?
Old 04-21-2009, 04:31 PM   #12
Saftety First!
Rewards Points: 77
Got faith in ya Mike.
Old 04-21-2009, 05:52 PM   #13
No I haven't gonna have to call someone in to do it.
BTW my name is not mike
Old 04-21-2009, 06:03 PM   #14
"Angus MacGyver (known to his friends as MacGyver or "Mac") who favors brain over brawn in order to solve desperate problems."
Old 04-21-2009, 06:28 PM   #15
Saftety First!
Rewards Points: 77
Sorry Angus, didn't mean no harm....I have a friend named Mike. Likes to call himself Mcgiver. Thought you might be him. That's all. When I seen those pics. of yours, first thing I thought was...that could only happen to Mike
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
