Need HELP Swapping A Vision Pro 8320u1008 To An IAQ One - HVAC - Page 8 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 10:54 PM   #106
Originally Posted by beenthere View Post
Premature doom and gloom.
Sir my Hat is off to you ....
Now i need to figure out a filter system fr my allergies and I will be set..
N01B4ME is offline   Reply With Quote
Old 01-06-2010, 11:03 PM   #107
An old Tradesmen
Rewards Points: 6,098
Any 5" media air filter will do a good job. With a MERV rating of 13 or higher. Just have to have the return duct sized for it. So it doesn't restrict air flow too much.
Old 01-06-2010, 11:15 PM   #108
You keep the heat at 77 ??
Old 01-07-2010, 12:01 AM   #109
I was only putting it that high just in case the heat pump would not work again tonight....lol
Old 01-07-2010, 10:10 AM   #110
Ok last night. I had to change the setting of 360 to 30 degrees for the heat pump to keep coming on. If I left it at 10 degrees it would come on and shut down 10 minutes later. This mean I have something confgured wrong.
I also temporarily turned off the de humidification thinking it was causing issues.The heat pump worked all night without issues.
Now my new problem is the heat pump efficiency was down because I had the tstat for 74 degrees and the heat pump was fighting to maintain 67 degrees. So I need to know how to make the em heat come on to assist the heat pump to get to the desired temp.
These are the temps in my zipcode for last night..
Time (EST): Temp.:
12:53 AM 24.1 F
2:53 AM 23.0 F
3:53 AM 21.9 F
4:53 AM 21.0 F
5:53 AM 21.0 F
6:53 AM 19.9 F
7:53 AM 21.9 F
8:53 AM 33.1 F
9:53 AM 45.0 F
Old 01-07-2010, 02:27 PM   #111
Wow I just went through your thread and that is allot of work. Amazing how much work you are putting in to the renovation. It will look awesome once completed.
Old 01-07-2010, 02:29 PM   #112
An old Tradesmen
You want the aux heat to come on, not emergency heat. Emergency heat is just the expensive strip heat, without the heat pump.
If running the heat pump only was able to maintain 67, when it was 24 outside.
Then it can maintain a difference of 43 outdoor to indoor temp.
So then your balance point to maintain 74 would be: 74-43=31F.
Post all your installer set up settings as they are now.
Old 01-07-2010, 03:51 PM   #113
110 0
120 20
130 10
140 1
150 7
160 4
165 0
172 2
174 1
176 1
190 0
200 0
220 2
240 E
280 1
300 1
310 5
320 0
330 2
340 0
342 1
350 0
360 30
365 E 0 upper right
370 1
372 E 0 upper right
379 1
383 3
390 0
400 0
500 2
502 0
510 E 0 upper right
520 E 0 upper right
530 1
540 4
580 5
600 90
610 60
640 12
650 0
660 0
670 0
680 2
690 2
700 1
701 0
710 0
Old 01-07-2010, 04:22 PM   #114
An old Tradesmen
Settings are basically right.
Its probably not charged correctly, and a sfety is shutting it down.. Or a miswire with the outdoor unit.
Old 01-07-2010, 04:29 PM   #115
I rewired the outdoor unit like depicted in the beggining of the thread. I will double check right now to see if anything is wired incorrectly...
Be back in a few.
Old 01-07-2010, 04:47 PM   #116
An old Tradesmen
Relooking at what you posted for teh outdoor unit. I don't see that the defrost board is wired to bring on the strip heat during defrost.
Old 01-07-2010, 05:03 PM   #117
I was able to bring on the aux heat by messing with the settings of 350 and 360 the first night...
I will repost the change of the W2 that was asked previously in the thread.
W2 brown goes to W2 inside the Air Handler. I did not have a white piece of wire..
Old 01-07-2010, 09:23 PM   #118
I will attempt to check it myself and let you know what pressures I have. If it gets too hectic it might be time to call the professionals.
Old 01-10-2010, 02:46 AM   #119
This is my only problem. When the heat pump auto defrost's it blows cold air in the house. I was thinking my heat pump was not working ocrrectly and shutting off. It was shutting off to autodefrost. I just dont undertand why it is blowing cold air out of the vents when the heat pump does this. After the auto defrost my air vent temps are 94 degrees.
I have the tstat set at 73 deg and the inside temp is maintaing 70 at this time with an outdoor temp sensor reading of 29 degrees.
Old 01-10-2010, 08:18 AM   #120
An old Tradesmen
You need a wire from the outdoor unit's W(W2), to the indoor units W1 or W2 terminal.
Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question chetwynd HVAC 3 02-08-2012 11:36 AM
Need help with Honeywell Vision Pro Thermostat...frozen in NJ ronaldpalka HVAC 15 04-24-2009 04:11 PM
Vision pro 8000 problem chucky7 HVAC 2 01-25-2009 08:21 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 06:55 PM
Swapping panel out JohnTelcoMan Electrical 7 09-05-2007 08:12 AM
