Need HELP Swapping A Vision Pro 8320u1008 To An IAQ One - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 07:12 PM   #76
HVAC
The bad part is my dad needs a new AC and I have called like 7 technicians and they are all horrible. I am not bad mouthing techs in general. it is just the ones in my area . I need to find one to put a whole new system in his house as it is on its last legs.
I would check with your utility company on contractors and ask the manufactures, who in your area they recommend. These two may help in selection of who to deal with.
KAVF is offline   Reply With Quote
Old 09-05-2009, 10:27 PM   #77
OK guys I wired up the outside sensor and added the white wire on the coil to W2 and in the air handler put the white cable form the outside to W2. I also set the dealy on the air handler to off so the IAQ is now contorlling hte blower for humidity control. The outside sensor is dead on I could not believe how accurate it is to wundergorund.com ...
I have a question my return upstairs by the AC is 24x18 and the one in the kitchen is 12x12. Is this enough for a 4 ton?
Should I make the 24x18 bigger to suck up more air. The filter in their bows in like it is going to get sucked up in the furnace.
I love the IAQ, It is an awesome thermostat.
N01B4ME is offline   Reply With Quote
Old 09-05-2009, 10:40 PM   #78
An old Tradesmen
Rewards Points: 7,816
A bit small. Should increase the first floor one(not suppose to have a return in a kitchen or bathroom).
The second floor should be increased. And a 16 x 24 on the first floor would help.
Old 09-05-2009, 10:48 PM   #79
I saw that after reading but the whole is already in the kitchen. What would be the benefit of making the one in the kitchen bigfger opposed to the one updstairs. The one upstairs is easier to enlarge.
Pics of my returns, thermostat, and air handler.
Old 09-06-2009, 05:13 AM   #80
An old Tradesmen
I said increase both.
If you can only increase the second floor. Then just increase that one.
Once you increase the second floor return. The first floor return will draw less air. Thats why I said to increase both.
Old 09-17-2009, 07:02 PM   #81
I have some new questions. Does the humidity control on the IAQ waste electricity?
I have been measuring my KWH daily and am averaging 62-65kwh. I checked all the electricity in the whole house in the past month to see what was causing my electric bill to me high.
I went out and replaced 3 plasma TV's to LCD LED tv's ans notice a huge difference with a killawat meter. I also went out and bought the Samsung HE front loaders because they claim it uses only 33kwh per year which is impressive if correct. I also replaced my water heater to a Titan Tank less to conserve their are well.
We do not cook hardly so that is not a factor.
I am thinking the ac is the major energy hog in my house. Is this true?
Old 09-17-2009, 07:57 PM   #82
An old Tradesmen
It can be. If your A/C is oversized, it will use more electric.
Also, depends on how low the humidity is set for.
Setting it for 50%, shouldn't cause the A/C to use a lot more electric, unless is oversized for your house.
Old 09-18-2009, 08:38 AM   #83
Isn't it better on the electric meter if the VS blower is running slower to dehumidify the house thanto run full blast most of the time?
Old 09-18-2009, 10:58 AM   #84
An old Tradesmen
Its a catch 22.
While the blower is using less electric per hour at a lower speed/CFM.
The blower and compressor both are running longer.
So it becomes a question of how long is too long.
Old 09-21-2009, 04:38 PM   #85
Its a catch 22.
beenthere,
I wanted to come here and tell you that YOU ARE THE MAN
I was jumping the gun on the electric bill usage.
Here is my usage from the past months
July 09 80 KWH thermostat was wired incorrectly by installer and settings were never set on the Viison Pro 8320u1008
August 09 65 KWH Per Day fixed thermostat settings on Vision Pro
Sept 09 59 KWH per day - swapped out to the IAQ and set the blower to 350 CFM per request.
August was the timeframe you were helping me along with others on a diff forum which helped reduce my KWH per day.
Old 09-21-2009, 04:43 PM   #86
An old Tradesmen
Glad to hear everything is working out good for you.
Old 09-21-2009, 04:45 PM   #87
I f I can only find a Master AC tech in my area like you I would gladly give him my hard earned money to replace my dad's AC system. The hard pasrt is finding a good tech.
Old 09-21-2009, 04:47 PM   #88
An old Tradesmen
On another site I belong to.
There are many members from Florida. That can do a very good job.
Old 09-22-2009, 08:32 AM   #89
I was researching that and will ask thme theyre. Thanks Again..
Old 01-06-2010, 05:58 AM   #90
HELP My Heat pump is not working as it is 29 degrees outside. My aux heat comeso n but it blows cold air from my vents. I checked the settigs of 350 for compressor lockout and set it to 35 and 360 for the aux heat and set itto 0. I see in the thermiostatwhere it says aux heat on but no dice. It is only a 9kw is that enough?
thanks
Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question chetwynd HVAC 3 02-08-2012 10:36 AM
Need help with Honeywell Vision Pro Thermostat...frozen in NJ ronaldpalka HVAC 15 04-24-2009 03:11 PM
Vision pro 8000 problem chucky7 HVAC 2 01-25-2009 07:21 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Swapping panel out JohnTelcoMan Electrical 7 09-05-2007 07:12 AM
