09-03-2009, 03:25 PM
#61
Need HELP swapping a Vision pro 8320u1008 to an IAQ one
Originally Posted by yuri
Wait until we sell you a zoning system to go with your VS system. LOL  You have no idea what a complicated configuration setup is. These new units work great if a tech is interested in technology. 95% of the systems are left as is out of the box. That is why the customer has a warranty I was told." No news is good news".
LOL. On the bright side this weekend I installed a Kenmore Elite Water softener, a Titan Tank less water heater, and now with the help of you guys I am fixing the A/C...
The funny thing is my first shower with soft water was weird. I was in their for an hour trying to get the soap off of me..lol
09-03-2009, 03:31 PM
#62
Hvac Pro
I can get you a good deal on one of these:
http://www.lennox.com/products/overv...=Harmony%20III
that way you will have all the "bells and whistles".
09-03-2009, 03:40 PM
#63
I have no clue what that even does... What is the benefit of adding that to my system?
09-03-2009, 03:45 PM
#64
Hvac Pro
You can have motorized dampers installed in your ducts and control them with separate thermostats and create comfort zones. Ductwork needs to be accessible and of the right size and layout.
09-03-2009, 03:53 PM
#65
Wow I just seen a video presentation of that setup. That is pretty slick. My house is 2 story so I have no clue where the vents are running for the downstairs portion.
09-03-2009, 04:14 PM
#66
Hvac Pro
No Problema, nothing a new house couldn't solve.
09-03-2009, 04:58 PM
#67
Yuri,beenthere, and KAVF Thank You again. I came home and today the house felt better than it ever has with this AC system. I have been in my house for 6 years and honestly can say the ac feels like it should. Before I would come home from work and the Vision Pro would be set to cool to 78 before I got home at 5:00pm. It would have issues attaining that temp before I would walk in. Today I came in 1 hour earlier than ususal and went immediately to the tstat. I seen recovery cool on and it read 79. I hit the keys to lower it to 77 and the VS blower kicked on higher to cool the house faster.
What caused the VS blower to speed up when I lowered the temp? Pretty cool as it has never done that before.
I see oyu talk spanish..lol I am spanish myself. GRACIAS.
09-03-2009, 05:15 PM
#68
An old Tradesmen
Digital thermostats often jump up or down a degree when you manually change the temp. And often times, the humidity reading will also. So good chance the blower was slowed down for humidity. And when you set the temp lower. It registered a higher temp, which made the humidity register lower. And allowed the blower to go to the set cooling speed.
Not real uncommon when the set temp is changed manually.
09-03-2009, 05:22 PM
#69
Wow that is exactly what I did and what happened. You know your stuff man  .
When I setup the thermostat yesterday it was default for 3 CPH but I changed it to 2. How do i find the correct one? The reason why I chose 2 is because I had a short cycling before and now since moving cables around the dynamics of the system has changed right? So should i change it to 3 cph or leave it at 2 cph?
Also how do I figure out how much electricity the coil and the air handler runs me? I am just curious
09-03-2009, 05:46 PM
#70
An old Tradesmen
I'd set it back to 3.
The setting is only real accurate at 50% load.
Best way. Turn off all other appliances, including the water heater.
Then read electric meter, turn A/C on for 15 minutes, and read meter again. That will give you a rough idea.
Then turn your water heater back on, and any other appliances.
The amount of electric it uses will vary by the load its working under at the time. So it will vary from day to day.
09-03-2009, 05:50 PM
#71
I am about to cry. I think I am short cycling now. Tihsi s what I noticed from coming home.
5:11pm ac turned on
5:17 off
5:23 ac turned on
5:28 off
5:35 ac turned on
5:41 off
5:48 ac turned on
09-03-2009, 05:58 PM
#72
An old Tradesmen
What do you have the humidity set to. That over rides the CPH setting.
It could be that its trying to dehumidify. What is the humidity reading.
Another thing you might want to try.
Since its a 4 ton unit. Set the blower speed/CFM to something between 1400 and 1600.
Short cycling would be an indication of an over sized unit/system.
09-03-2009, 06:00 PM
#73
The humidity reading is 50% and it is set to auto and the dehumidify setting on the right says 50 as well..
The blower is set to 1495 cfm..
09-03-2009, 06:23 PM
#74
An old Tradesmen
It can take a day or so for the stat to learn the house. So it may return to cycling closer to the CPH setting in a couple more hours.
If not.
If your short cycling at a CPH of 2, you can go to a setting of 1.
It could leave you with a bit wider temp swing then you will like though.
You could also try a lower blower setting. Say 1350 or so.
Something else you may want to check. Is that with the blower finally at its proper setting, that it didn't open up a supply or return duct from the increased pressure. And is allowing fresh unconditioned air to come in during the off cycle.
09-03-2009, 07:59 PM
#75
If not.
I will wait a day or two to see how the system does. I still need to wire the W2 to the air handler, need to wire the outside sensor and set the switches to no delay. I will do all that and let you know how the system is at that point.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
