Need HELP Swapping A Vision Pro 8320u1008 To An IAQ One - HVAC - Page 11 - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 12:50 PM   #151
An old Tradesmen
Rewards Points: 8,234
Yes, 360 is the aux heat lock out.
If you want to test if aux heat comes on when the stat calls. Set teh lock out to no lock out. And set the temp on the stat 5 degrees higher then room temp.
Or, go into installer test, and run the test modes.
As for testing in defrost. You can jusp the defrost boards test pins, and force it into defrost. But, it could terminate defrost before you get back inside.
Old 01-14-2010, 05:08 PM   #152
Wow it works finally. Now I can feel the heat....
N01B4ME is offline   Reply With Quote
Old 01-14-2010, 05:30 PM   #153
An old Tradesmen
Congrats.
Old 01-14-2010, 06:03 PM   #154
Congrats.
Thanks Again.....
Old 01-19-2010, 08:48 AM   #155
Congrats.
Today was the first day I actually used the aux heat with the heat pump. Wowzer it puts out heat now..lol
I accidentally left the system off last night and woke up at 2 am with the house like 55 degrees... brrr it was cold. I set the system to auto and the heat pump and aux heat went to town. It warmed up the house in an hour..
Old 01-19-2010, 09:13 AM   #156
An old Tradesmen
I accidentally left the system off last night and woke up at 2 am with the house like 55 degrees... brrr it was cold. I set the system to auto and the heat pump and aux heat went to town. It warmed up the house in 1/2 hour..
Don't forget.
Everytime the aux heat comes on. Your electric meter spins faster. Meaning higher electric bill.
So in that hour with the aux on. You used 5KWs of electric for the aux alone.
So you don't want to use large temp swings when you change your thermostat temp setting.
But, it is nice when a system warms the house up fast.
Old 01-19-2010, 09:16 AM   #157
Don't forget.
Yeah I was checking to see if the aux heat would work and it felt like my oven. I did notice the aux heat comes on if the temp diff is mor than 3 degrees. Is that normal?
Old 01-19-2010, 09:40 AM   #158
An old Tradesmen
If you don't have lock outs set.
The aux heat will come on if the IAQ determines that the HP is operating at 90% of its ability to heat the house.
Which means it can come on even when the stat reads that the house is at set temp.
If you manually raise the set temp 2 or more degrees. The aux will come on.
Old 01-19-2010, 09:41 AM   #159
So If I set a lockout temp, will my heat pump still use aux heat to defrost? I want to make sure that cold breeze doesn't happen anymore as it was cold.
Old 01-19-2010, 10:00 AM   #160
An old Tradesmen
Yeah. The stat has no control over defrost. The outdoor unit sends the W signal directly to the air handler.
The Following User Says Thank You to beenthere For This Useful Post:
N01B4ME (01-10-2011)
Old 01-19-2010, 10:13 AM   #161
Thanks I was worried If I set a lockout temp my defrost would not work....
Old 01-10-2011, 02:30 PM   #162
Well I wanted to report my AC and heat have been working good. Knock on wood .
Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question chetwynd HVAC 3 02-08-2012 10:36 AM
Need help with Honeywell Vision Pro Thermostat...frozen in NJ ronaldpalka HVAC 15 04-24-2009 03:11 PM
Vision pro 8000 problem chucky7 HVAC 2 01-25-2009 07:21 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Swapping panel out JohnTelcoMan Electrical 7 09-05-2007 07:12 AM
