Need HELP Swapping A Vision Pro 8320u1008 To An IAQ One - HVAC - Page 10 - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 04:50 PM   #136
Originally Posted by beenthere View Post
Well. 5KW(17,065BTUs) at 1600 CFM is only a 9.8 temp rise.
10KW(34,130BTUs) at 1600 CFM is a 19.5 temp rise.
You probably aren't getting a full 1600 CFM. But that is what your 4 ton heat pump wants.
Around here, a 4 ton heat pump has at least 15KW of strip heat.
In your are you probably don't need that much.
I just want to combat the cold air from the defrost mode. All the changes you suggested have helped tremendously. the last 3 nights have been cold but the HP was only fighting 1-2 degrees to maintain 73 degrees throughout the night. How about a 8k heat strip?
N01B4ME is offline   Reply With Quote
Old 01-11-2010, 04:57 PM   #137
An old Tradesmen
Rewards Points: 7,404
They don't always come in a large multiple selection of KW sizes for every brand unit.
Some brands will have a 7.5, others a 9.2, still others will have a 6KW, and others a 10 KW.
I don't believe your comes in an 8KW.
Old 01-11-2010, 05:02 PM   #138
I guess I am screwed then. Because new wiring to the air handler is a nightmare as it is a 2 story house ... Now shouldn't the 5kw at least help combat the cold air in defrost mode?
Old 01-11-2010, 05:13 PM   #139
An old Tradesmen
With the 5KW on during defrost. On a heat pump your size. I would expect the air temp from the registers to be 10 to 12 cooler then room air temp.
Without the 5 KW. Probably 20 to 24 cooler.
Old 01-11-2010, 05:15 PM   #140
Man I think a room heater is easier than going through these headaches . LOL
Old 01-11-2010, 05:18 PM   #141
An old Tradesmen
Is your line set ran up through your wall?
Or, on the outside of the building.
Old 01-11-2010, 05:25 PM   #142
Through the wall and I just realized how to run it through the walls from the garage to the AH area .... The same area I used for running my cat 5 and RG6 cables...
Old 01-11-2010, 05:30 PM   #143
An old Tradesmen
There you go.
Old 01-11-2010, 07:01 PM   #144
Can I run another 8-2 and couple it with the existing, or should I run 6-2 new wire?
Old 01-11-2010, 08:33 PM   #145
An old Tradesmen
Better run run a 6-2.
Old 01-12-2010, 02:22 AM   #146
interesting post great reading. I would take into consideration before i undertake all that rewireing that the current fl. temps are way way beyond the norm and during most fl winters your defrost cycle may be almost nonexsistant creating almost no situation where the strip heat was even being used, that being said if the outdoor unit takes a dump youre certainly not going to heat that house with 5 kw. So carry on......depending on the temp rating of the insulation on the exsisting wire it can be legal for up to 55 amp load if it has a insulation rating of 90c which is stamped on the wire. i tried to cut and paste a chart from the nat. elec.code here but it didnt work. so rewireing may not be needed. if you google wire gaugeing it should come up
kennzz05 is offline   Reply With Quote
Old 01-12-2010, 05:27 AM   #147
An old Tradesmen
And what was the voltage drop .
Old 01-13-2010, 11:00 AM   #148
less that 5 volts for 100 feet
Old 01-13-2010, 01:27 PM   #149
An old Tradesmen
Since the blower motor is an inductive load.
That 5 volts will raise the motors amps slightly(not much).
The amp draw on his strip heaters will decrease slightly(not much).
Making him use the same amount of electric for less heat output.
Of course his wire may not be rated for 90C.
Old 01-14-2010, 10:49 AM   #150
OK he came and installed the new 10KW heat strip and changed the breaker to a 50 amp and switched both wirs to W1. He turned on the EM Heat to show me the strips kicked on. I could smell the burning since it was a new piece and physically seen the red coming form the heat strips.
I measured with the raytech gun and felt the heat coming out of the vent. So how do I check if the aux heat comes on. I think I set the option 360 to 30 degrees. does that setting lockout the aux heat until it hits 30 degrees? How can I tell if the defrost is kicking on the aux strips?
I also am ordering 6-2 to run a new wire to the main fuse box.
Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question chetwynd HVAC 3 02-08-2012 10:36 AM
Need help with Honeywell Vision Pro Thermostat...frozen in NJ ronaldpalka HVAC 15 04-24-2009 03:11 PM
Vision pro 8000 problem chucky7 HVAC 2 01-25-2009 07:21 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Swapping panel out JohnTelcoMan Electrical 7 09-05-2007 07:12 AM
