-   -   Need HELP swapping a Vision pro 8320u1008 to an IAQ one (http://www.diychatroom.com/f17/need-help-swapping-vision-pro-8320u1008-iaq-one-52121/)
N01B4ME 09-01-2009 10:13 AM
I need help swapping from a current Vision Pro TH8320U1008 to a newer IAQ thermostat.
I will take pics of thecurrent wiring for reference. Would I gain anything from changing to this thermostat. My main goal is control humidification from my air handler to slow my VS blower.
This is what I have wired currently on the vision pro. It looks like I have extra wires to wire in the outdoor sensor. My model #'s for my Furnace and Heat Pumps are:
My Heat Pump is Model FT5BD-048K and Furnace B5VM-T49K-C
http://i209.photobucket.com/albums/b...R/CIMG1547.jpg
Thanks,
Tony
yuri 09-01-2009 02:58 PM
Which Brand of heatpump and air handler do you have?
N01B4ME 09-01-2009 03:24 PM
Both of them are frigidaire By Nordyne. Model #'s for them are:
Heat Pump Model FT5BD-048K
Furnace B5VM-T49K-C
Here is a pic of the wiring on the Air handler
http://i209.photobucket.com/albums/b...CIMG1553-1.jpg
Here is a pic of the dip switch settings on the air hander
http://i209.photobucket.com/albums/b...R/CIMG1556.jpg
http://i209.photobucket.com/albums/b...R/CIMG1557.jpg
http://i209.photobucket.com/albums/b...R/CIMG1565.jpg
N01B4ME 09-01-2009 05:04 PM
By looking at the wiring it only uses 4 wires coming from the Heatpump outise.
Cyan Blue --- C
Red --- R
Yellow -Y1
Orange -O
Inside wiring towards thermostat is usng 6 wires.
Cyan Blue --- C
Red --- R
Yellow -Y1
Orange -O
White --W2
Green-- G
yuri 09-01-2009 06:07 PM
Fridgidaire not popular where I am. Hang in there, one of the other techs may help if you can wait a day.
KAVF 09-01-2009 06:16 PM
I'm not that familiar with Nordyne VS units, but I don't see a DeHum anywhere to slow blower down 20% for dehumidification. Does the Pro 8000 stat you have now have dehum? That could be set and it would run a/c up to 3 deg lower than setting to try and reach desired humidity level.
N01B4ME 09-01-2009 06:22 PM
If you look at the pic of the dip switches. Their are 2 HUM terminals that are jumped. The Vision Pro 8320 does not have dehumidificaiton control. That is the reason I want to swap it out to the new IAQ VIsion Pro.
KAVF 09-01-2009 06:37 PM
Sorry I'm used to hum meaning humidify. According to Nordyne it can be used to dehumidify.
8. OPTIONAL HUMIDISTAT
(Variable Speed Only)
The optional humidistat may be installed in the
return air duct to provide excellent humidity
control when needed and maximum system
capacity and energy effi ciency when humidity
levels are normal. The humidistat senses when
humidity in the return air stream is above a preset
level (fi eld adjustable) and sends a signal to the
motor to reduce the airfl ow so that more moisture
may be removed until the humidity level drops.
The air handler is pre-programmed for humidistat
operation. Remove jumper connector installed
between the two terminals marked “HUM” on
the circuit board.
Note: The 15+ SEER air handlers that are
matched with a 2-stage cooling outdoor unit
and the humidistat is installed will not drop
below 75% of the selected blower speed when
the system is operating in lo-cool mode and the
humidistat opens.
Installation— Install the humidistat in the return
air duct as directed in the installation instructions
included with the kit. Wire the humidistat through
the low-voltage wire entrance in the air handler
(Figure 1) to the quick-connect terminals marked
“HUM”. Wire the humidistat to open on rise in
humidity.
N01B4ME 09-01-2009 06:41 PM
the circuit board.
humidistat opens.
humidity.
So can it be wired into the VIsion Pro IAQ then? Please tell me it can as I have the thermostat here. My intention was to use it to control the humidity in my house. FLorida is Hot and Humid..lol
KAVF 09-01-2009 06:49 PM
I would say you can wire it up. I am trying to look at installation mauals for IAQ with no luck downloading it yet
N01B4ME 09-01-2009 06:50 PM
Heres are the manuals.
This is the Manual for the EIM that all wires go to.
http://customer.honeywell.com/techli...69-1823EFS.pdf
This is the thermostat itself. IT only uses 3 wires from the EIM
http://customer.honeywell.com/techli...69-1816EFS.pdf
KAVF 09-01-2009 07:08 PM
Looks like you will wire the two hum terminals from furnace to the two dhum terminals on the interface. Did you configure you old 8000 stat? Configuration can be fun on these
N01B4ME 09-01-2009 07:09 PM
Yes because the AC installler left it all default and I was having issues.
I just need to verify the wiring from you guys. You guys are the pros :).. I am a pro in networks:thumbup:.
Is this correct.
Wires to the new EIM
Cyan Blue ----------to C
Red -----------------to R,RC,RH
Orange --------------to O/B
White ----------------to Aux
Yellow -----------------to Y
Green ------------------to G
HUM -------------------to HUM1
HUM -------------------to HUM2
KAVF 09-01-2009 07:23 PM
I see you are in Fl as well. What is your humidity level in the house? It should be on a properly set up system around 50% these days. If not your system may have not been set up correctly, IE too much airflow, A/C too big ect.
Is this correct.
HUM -------------------to DHUM1
HUM -------------------to DHUM2
Change to these for dehumidification.
I don't know the humidity in my house. How can I tell?
Thanks for all of your HELP...
Once you get this hooked up it will take awhile but it will tell you.
N01B4ME 09-01-2009 07:26 PM
