Need Help For Rheem Hard Start Kit - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 08:39 PM   #1
Rewards Points: 91
Need Help for Rheem Hard Start Kit
Can anyone advise the Rheem part number (or Grainger #) for the hard start kit.
I have Rheem model# RAPL060JAZ
serial# 7713M200811399
I have a whole house generator but when the AC comes on the lights dim quite a bit. The generator is 18Kw.
George6488 is offline   Reply With Quote
Old 03-07-2013, 09:08 PM   #2
Rewards Points: 282
check out this link at grainger. See if this helps.
link here
jmon is offline   Reply With Quote
Old 03-07-2013, 09:35 PM   #3
REP
Dimming of lights without throwing the breaker means you have other problems.Either you have other things on that line or the wiring is undersized or loose at the connections.This must be figured out as it is a fire hazzard.If you had the misfortune of a fire abnd the insurance co finds the problem they are off the hook.A hard start kit is ok and might help but a real electrcian should go overe ewverything just to be safe.
REP is offline   Reply With Quote
Old 03-08-2013, 05:59 AM   #4
Rewards Points: 1,216
If your unit always ran good on normal POCO power supplied to your residence I wouldn't mess with it .
I think your just looking for trouble.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-08-2013, 03:27 PM   #5
An old Tradesmen
Rewards Points: 7,370
The SUPCO MPR5 would be appropriate for your 5 ton condenser.
Old 03-08-2013, 03:38 PM   #6
If you are dropping voltage during all or part of the day, this too can cause the dimming of lights. It may not be anything wrong with your stuff, it could be that the service is overloaded. For instance, if a transformer is overloaded it can cause lights to dim when the unit starts. It can also cause a compressor to overheat and trip out on thermal overload. Good thing to do is to check voltage during the peak demand times of the day. Try to check it for voltage drop when your own unit kicks on.
surenuff is offline   Reply With Quote
Old 03-08-2013, 06:49 PM   #7
Rewards Points: 980
None of that is true.
Practically ALL "accidents" are caused by someonedoing something wrong. If the insurance company was allowed to not pay because of that, then insurance would be really cheap.
Lights dim when there is voltage drop on the line. If you had to put in wires capable of handling starting currents without voltage drop, wiring a house would be prohibatively expensive.
There could be a problem, but it is common without there being a problem. In this case the generator is probably marginal for the load.
Toller is offline   Reply With Quote
Old 03-09-2013, 02:42 PM   #8
Rewards Points: 91
The electrical is all OK. When running on generator......the starting load of the AC causes the generator to rev up to put out the extra power. This is when the lights dim and it is only for a second or two until the generator catches up with the load and then all is OK.
I just thought a hard start kit might make it easier on the generator.
Any thoughts?
Old 03-09-2013, 03:00 PM   #9
An old Tradesmen
Yes, it will.
Hard start for compressor bob22 HVAC 3 01-13-2013 07:54 PM
Adding a Hard Start Kit rgarcia1801 HVAC 11 10-21-2012 05:31 PM
is a hard start kit needed???? firedogut HVAC 3 10-08-2009 06:33 PM
Snapper Mower engine hard to start czars Tools 3 09-02-2009 01:38 PM
How hard is your water? How deep is your well? brokenknee General DIY Discussions 10 05-05-2009 07:17 PM
