Need Help Quick - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 07:21 PM   #1
need help quick
i have gas heat and it is not working. supposed to be 9 degrees tonight so. the problem i am having is that as the heat cycles, the burners ignite, but then go out right before the blower comes on. so that it is blowing out cold air. any help with this would be appreciated.
wolvenar is offline   Reply With Quote
Old 01-21-2013, 07:53 PM   #2
I'd get busy looking for threads with a similar problem to yours.
I'm a newbie, but I'd look to see if your control board has an LED which puts out a code to diagnose the error. Or check the flame sensor; there's a recent post with a link to a Youtube video.
Good luck.
bausin is offline   Reply With Quote
Old 01-21-2013, 07:56 PM   #3
is it an 80 or 90% efficient furnace? How old is it?
Sounds like a flame sensor ...can't be sure with out more info.
hvac5646 is offline   Reply With Quote
Old 01-21-2013, 08:21 PM   #4
Rewards Points: 13,296
No make, no model #.
What 's the chances your going to have the needed parts laying around to even fix it this late?
Better get on the phone and call for service.
Old 01-21-2013, 08:51 PM   #5
Rewards Points: 582
sounds like a dirty flame sensor...post picture of furnace with upper door off..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (01-22-2013)
Old 01-22-2013, 03:28 AM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Pull the flame sensor out after shutting power off to furnace.
Im guessing its on opposite side of burner compartment from igniter,it will look like a rod with wire connected to top of it .
Clean it with a scuff pad and reinstall,a picture of front of furnace with door off would make it easier to direct you to the location
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-22-2013, 07:27 AM   #7
Rewards Points: 582
well I guess he diden't help that quick after all...you guys did a good job in responding to this one ..... ben sr
oh'mike (01-22-2013)
Tarkett Vanguard Quick Loc Hardwood Floor wlwin61 Flooring 100 02-16-2017 08:38 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
Quick Release Fence Post JasonCA Building & Construction 8 02-14-2012 10:15 AM
Quick Step perspective flooring dawnparkin545 Flooring 1 06-25-2011 12:51 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
