Need Help With Plenum And Duct Building! - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 10:56 AM   #1
Need help with plenum and duct building!
I am making preps to rip out my old fiberglass plenum and ducting and replace it. The current plenum is 18 inches deep, 25 feet long and 10 inches in height. All of the 8 inch flex ducting is coming off the top and then has to make a 90 degree turn to go to each room. This causes the ducting to pinch and restrict the air to certain rooms. The rooms with the longest ducting have minimal airflow coming out.
I plan on using 8 inch ducting from the plenum and then install 8x6x6 wye connectors to split the ducting to the rooms.
I need to know how to determine the correct size for a plenum. Need to know how to determine how many registers are needed based on size of room.
Motchedo is offline   Reply With Quote
Old 07-28-2011, 11:07 AM   #2
JJboy's Avatar
YOu just need to learn these manuals:
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 11:45 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Need help with New HVAC Reducing Plenum Duct Design Matt2010 HVAC 1 11-14-2010 04:48 PM
Plenum to duct branch off placement question BlueBSH HVAC 5 03-03-2010 02:37 PM
Need to add 10" duct to plenum. Looking for DIY. 01sport HVAC 4 01-15-2009 02:00 PM
