Need Help With New Line For Small Bathroom - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 03:19 PM   #1
need help with new line for small bathroom
I want to add a floor register to my bathroom, which has none in it now. I want to make it simple and cheap, and I was planning on using a 5" insulated flex duct into my crawlspace from furnace on main floor. Then i was going to put a damper in the duct right before it goes into the 6" inlet floor register. My questions are is this okay? The bathroom is really small, like 49 or so square feet. Thats why the damper. And how do i attach a floor boot. They dont have ears on them or anything, at least the ones at menards dont. Also, can i even get a floor register with a 4 inch inlet, to run a smaller branch and not have to use a damper?
rboutin2 is offline   Reply With Quote
Old 10-02-2011, 04:28 PM   #2
An old Tradesmen
Rewards Points: 6,930
Use dry wall screws to fasten it. Because your running flex all the way, you'll want atleast a 5"
Old 10-02-2011, 08:19 PM   #3
REP
Keep the flex as stright as possible,tight and forget about the damper you won't need it.
The boots I used had a half inch slit in each corner and I used a hammer to peen over the edge to the floor so that the flange held the boot in place.Screws work too.
REP is offline   Reply With Quote
Old 10-02-2011, 08:21 PM   #4
Rewards Points: 150
Yuuuuup +1
OhioHomeDoctor is offline   Reply With Quote
Electrical Line To Dishwasher - Faulty?? mike6679 Electrical 19 09-30-2011 01:37 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Re-wiring an existing bathroom Worker-B Electrical 7 08-29-2009 05:16 PM
