Need Help With Luxaire Trouble Code - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 06:44 PM   #1
Need help with Luxaire trouble code
I have a Luxaire gas furnace model # PCUHALD12N080C. Sometimes the hot surface ignitor will not light and the furnace will blow cold air. I flip the shut off switch on the furnace and it will work again. The trouble code is flashing red 11 times.
DustinP is offline   Reply With Quote
Old 11-29-2010, 07:04 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Should have a legend with the trouble codes on the front or back of one of the 2 doors. May be buried in the wiring diagram also. Post the code info here.
Old 11-29-2010, 07:11 PM   #3
I tried looking for it before, but all that was on there was the wiring schematic. Can you somehow determine what the trouble code is from the schematics?
Old 11-29-2010, 07:19 PM   #4
Hvac Pro
yuri's Avatar
No. And I don't have insider info with Luxaire/York tech info. Post the serial # here and maybe Beenthere may have access to York info. 2 things to try.
1) Clean the flame sensor with fine emory paper. Sits in front of one of the burners and looks like one of these
2) Remove the tube from the pressure switch where it attaches to the collector box, NOT the switch itself and ream that hole out with a paper clip or small drill bit.
Old 11-29-2010, 07:23 PM   #5
already cleaned the flame sensor.
Serial #(8) ELHM820656.
The tube from the pressure switch to the inducer motor appeared to be clear, but I will double check.
Old 11-29-2010, 07:25 PM   #6
Hvac Pro
yuri's Avatar
I found something:http://americanhvacparts.com/Merchan...ode=cb-johnson
Strange code (11) Broken rollout switch wire? Never heard of that problem. Maybe Beenthere or the other guys have. If it was broken it would not be an intermittent problem. The rollout switch wherever it is on those units may have a bad connection or you have a bad wiring harness or the board is faulty and giving false codes.
Old 11-29-2010, 08:12 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
i found something saying main blower failure for 11 flash.... not real sure that i believe that to be your problem though, if you look at the control board, it might give a legend on it, is it a white rogers board?
hvactech126 is offline   Reply With Quote
Old 11-30-2010, 09:47 AM   #8
I also found something on the internet saying the primary or auxilary limit switch has opened and remained open for more than five minutes, usually caused by a failed blower motor or blower wheel.
The blower motor seems to be working fine. Could the motor or blower wheel be in a bind, dirty, or getting hot causing the limit switch problem?
Does anybody know anything more on the one that said something about the broken rollout wire? I will try and do some research on this and see what I can find.
I appreciate the help.
Old 11-30-2010, 05:48 PM   #9
An old Tradesmen
Rewards Points: 6,112
Do you have A/C on that furnace. 11 Usually means the aux limit tripped.
Old 12-04-2010, 11:46 AM   #10
Yes, I do have a/c on it. So if it was aux limit tripped, what do I do?
Old 12-04-2010, 11:50 AM   #11
An old Tradesmen
See if the A/C coil is dirty. And clean it if it is.
Old 12-04-2010, 11:55 AM   #12
I will try that, but it doesn't have a heat pump or anything, how would the a/c coil effect the furnace, if it is not running?
Old 12-04-2010, 11:57 AM   #13
An old Tradesmen
The air has to blow through the A/c coil to get to the house.
Old 12-04-2010, 11:59 AM   #14
Ok, thanks.
Old 12-05-2010, 02:07 PM   #15
ok, I cleaned the A coil, but it didn't seem that dirty. After one day the furnace is blowing cold again. Is there a chance that the aux limit switch could be bad? I took the aux limit switch out to try and see if that would work, but it didnt. I put the limit switch back in, now the hot surface ignitor wont blow at all and the trouble code is giving 5 red flashes.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
Code Clarification GoyimPersuasion Electrical 24 01-28-2009 04:44 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Carrier 9200 Code 34 fault cu1982 HVAC 8 01-02-2009 09:56 PM
Day and Night Heater blink code 31 mlh HVAC 7 02-01-2008 12:57 AM
