Need Help With A Lennox Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 11:41 AM   #1
Home Repair Contractor
Need help with a Lennox Furnace
Hello Everyone, I hope someone can help me with this.
I have a Lennox furnace model# G23Q2/3 - 75 - 1. It is 16 years old.(date code 9-93)
I had a problem with the blower not coming on when the furnace fired up. After some research and reading a lot of info on this forum I figured it was the relay. On this furnace you have to replace the BCC. I bought and installed the new board and everything starts up as normal. Now when the house warms up and the furnace shuts down the blower keeps running. I can stop it by turning power off and back on. This stops the blower, but after about a 90 second delay the blower will start up again. The furnace DOES NOT start up only the blower. The new BCC is made by ICM Controls.
I'm a home improvement contractor but don't do a lot of HVAC work.
Any ideas anyone?
Drew
KCDrew is offline   Reply With Quote
Old 12-09-2009, 05:39 PM   #2
Sounds like your aftermarket board is not the right one. Lennox part number is a 48K98,believe it's made by heatcraft.
While you're there pull the blower assembly out and check the ring rivets on the heat exchanger.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 04:06 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
