Need Help With (Lennox 10ACB42-11P) - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 04:28 PM   #1
Need Help with (Lennox 10ACB42-11P)
I have a Lennox 10ACB42-11P outside unit and it just quit working yesterday (fan and compressor do not kick-in).
Upon checking with multimeter, seems like I am not getting 24V at the contactor for some reason. When I manually press and hold the contactor with a insulated screwdriver the compressor and fan kicks in. I have also replaced the dual run capacitor also.
When, I shorted the wire at the thermostat Y & Rc, nothing happens. I am thinking, maybe the 24 volt transformer located in the attic furnace maybe bad. Any ideas what should I do next?
FYI, when I change the thermostat setting to FAN from AUTO, the blower fan also does not come in.
a4ncar is offline   Reply With Quote
Old 09-27-2008, 06:51 PM   #2
SD515's Avatar
Rewards Points: 504
First thing I'd investigate is whether there is 120V at the furnace, (don't forget the 120V runs through the access door switch). 2nd would be to look for a blown fuse on the computer board in the furnace. If the fuse is blown, the next question is why.
Old 09-28-2008, 07:49 AM   #3
oops, did I do that!
Have you had any lawn work done lately? Inspect the low voltage wire going to the condensor for nicks or cuts.
8 Ball is offline   Reply With Quote
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 04:06 AM
Lennox Spring rebate? Hammerman HVAC 1 06-11-2007 06:38 PM
Small boom from lennox furnace mhenry48 HVAC 15 12-15-2006 06:36 AM
Lennox G11Q3E-110V-6 gas furnace neato5oh HVAC 1 10-07-2006 06:43 PM
