Need Help With Identifying Wiring On White-Rodgers Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 11:18 AM   #1
Need help with identifying wiring on White-Rodgers thermostat
We're replacing the thermostat (original) with a Rite-Temp 6022 (I know, baseline; we just need something moderately programmable). I've gotten the face of the White-Rodgers off (type 1F56W-444), but the wires don't appear to be labeled well at all. Here a couple of pics, and any info folks can share would be great. Thanks in advance! EDIT: Nevermind; I'm an idiot. I didn't even remember that the face needed to come off of the front. No worries; power's off. I've done this before, but it's been a while. Don't make fun; please.
Need help with identifying wiring on White-Rodgers thermostat-dsc_1121.jpg   Need help with identifying wiring on White-Rodgers thermostat-dsc_1122.jpg
luckie_reubs is offline   Reply With Quote
Old 05-07-2009, 11:43 AM   #2
An old Tradesmen
Rewards Points: 6,072
Remove those 3 screws.
Wire designations are on the back
Old 05-07-2009, 12:50 PM   #3
Yeah, I realized that immediately after I posted it. I feel like an idiot; I've got it all hooked up now; just need to check the jumpers.
Old 01-28-2011, 04:58 PM   #4
Thanks!
Just wanted to say thanks - and your error must be common! Sadly, I too was confused until I read your post and removed the second cover. Once I did that, it was simple - and my system is working!!!
jenwouters is offline   Reply With Quote
Old 07-28-2011, 10:19 AM   #5
Sorry, I'm new here and I must be really stupid. 1) I can't get the old thermostat off the wall, and 2) the wiring codes are on the back of what?
drav is offline   Reply With Quote
Old 07-28-2011, 10:30 AM   #6
Old 07-28-2011, 10:57 AM   #7
fabrk8r
fabrk8r's Avatar
Older thermostats have 3 parts. newer digital thermostats usually have two parts
The part that attaches to the wall is called the base-plate. It is what the thermostat wires attach to. Sometimes the wires are attached directly to the front where they are visible and some thermostats have the wires attached to the back of the base-plate before it is secured to the wall. This part will usually have letters to designate the attachment points of the corresponding wires.
The next part is the thermostat itself. It snaps or screws onto the base-plate and there are connections that fit together like a little plug that make low volatage electrical contact.
Some thermostats (analog) have a cover which snaps into place after everything else is connected.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 07-28-2011, 07:13 PM   #8
An old Tradesmen
lower left in that pic, see the letter "K", just to the right, loosen that screw. On the lower right side, you see that screw, loosen it, and then the one at top right.
Old 09-22-2012, 03:52 PM   #9
You saved me too !!
Yep, I could not figure out how to label my wires, with no letter designations. Found your post about needing to remove the thermostat itself, and which screws did that.....voila! From that point on it was a walk in the park.
Just registered to join this site so I could say thanks to all. I will certainly be back I am sure.
PCBFla is offline   Reply With Quote
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Wiring a Noma Programable Thermostat 111jag General DIY Discussions 1 10-14-2007 11:13 PM
