Need Help Identifying An AC Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 12:38 PM   #1
Need Help Identifying an AC Unit
http://imgur.com/a/e5ewl#0
I'm trying to find a replacement guard for the outside. (The first item shown above) I can not figure out what this unit is. There is no brand markings that I can find. The wiring schematic has no information other then the circuit. It looks like it could be a Lennox HS series, but the dimensions don't match. The only type of part numbers I can find are on the fan motor and the compressor. I can get that information if it might help.
Dlucks is offline   Reply With Quote
Old 08-26-2012, 01:13 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I'd ask the home owner (yourself?) if when that system was installed if it was a matching complete system. If it was (even if they/you don't know) I'd check the furnace and the evaporator coil for information on size and brand and go from there.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-26-2012, 05:42 PM   #3
An old Tradesmen
Rewards Points: 6,132
Check for a label near where the copper lines go in it. Doubt you'll find a new guard for it anymore.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (08-26-2012)
Old 08-26-2012, 08:05 PM   #4
Rewards Points: 91
had the same problem recently all the paper labels had been weathered or came off due to condensation trap clogging.
Basically I just looked at all the model numbers on the specific parts that had them still like condenser fan, compressor, A coil, and figured out by searching the internet for these parts narrowed it down until i found a manual and model.
no_Wedge is offline   Reply With Quote
Old 08-26-2012, 08:44 PM   #5
Missouri Bound's Avatar
My guess is that is a Gibson. Circa 2000....start there.
Do you want it your way or the right way?
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 10:33 PM
