*** Need Help Hydro Air Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 09:15 AM   #1
*** Need help Hydro Air Heat
Hello,
Just bought a house in CT that has unoccupied for few months. No electricity at the place at the moment. Breaker is probably off. The house has Hydro air for heat and two separate Lenox ac units.
My concern is the heat. With the cold months ahead of us. What do I need to know to get the heat turned on and get it going. Heating furnace runs on oil.
I am thinking may be have an HVAC company come out and give it once over.
I got to also winterize the pool as it been ignored.
Any insight would be appreciated.
cam444 is offline   Reply With Quote
Old 11-20-2011, 09:30 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
I would get it serviced properly. Oil filter in tank needs replacing as well as oil nozzle in burner and it should be setup with a combustion analyzer so it burns cleanly and uses less oil and for safety reasons.
Old 11-20-2011, 02:06 PM   #3
An old Tradesmen
Rewards Points: 6,548
Get the electric turned on, and then have it serviced and checked for complete proper operation, including the blower/air handlers.
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
