Need Help With HVAC Duct In Basement... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 11:48 AM   #1
Question
Need help with HVAC duct in basement...
Hi there. My husband is toying with the idea of finishing the HVAC ductwork in our basement himself. The situation is that there are already two vents cut into the ductwork in the ceiling, but we had to frame in and drop the ceiling to incorporate and close in a load-bearing beam. Before we put up the drywall, we need to bring the current vents down to the new lower ceiling level. How should he do this? Is there some sort of connector to do this? How hard will this be? Can he do this himself with materials from Menards or Home Depot or should we just hire a professional?
I hope this makes sense. Thank you for your help!
tbuchner is offline   Reply With Quote
Old 01-12-2011, 07:16 PM   #2
Have a local sheet metal shop make some sleeves and boot ears. Give them the measurement between the duct and drywall. Probably looking at $15-$20 cost.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
How to frame door under hvac duct cai Building & Construction 5 06-15-2010 08:05 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
Splitting HVAC flex duct dphens HVAC 16 08-19-2009 03:47 PM
