Need Help With HQCO Electric Heater Info - HVAC - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 11:02 AM   #1
Need Help with HQCO electric heater info
I have an issue with a HQCO heater (which I heard was actaully Heil???). The fan motor lost a bearing and after buying a replacement motor now the blower wheel appears pretty bent as once put together it won't rotate freely in the squirrel cage housing. Also, I now notice that the back plate of the housing is missing (which also contains the bearing for the end of the shaft of the motor). Where can I buy the blower wheel and back plate for the housing? Do I need to just buy an assembly minus the motor? Would there be a universal unit available, or do I buy a unit exactly made for this heater? Can anyone tell me the approximate age of this unit? Any info would be appreciated thank you.
HQCO Lewisburg, TN
Style# AMEO84A47
Model# 867.587 241
Ser# H05154854889
Mfr# SMEA084AH01
100 amp element
84,200 btu
rated 5 amp 1/3 hp motor
kw rating at 240 volts 24 67
Got this issue handled alone, thanks guys!
moparmusclecars is offline   Reply With Quote
Turning off electric water heater when not in use? skipjack Green Home Improvement 10 03-08-2011 09:02 PM
Electric Baseboard Heater Is it O.k. to mount directly on Floor bltglt507 HVAC 4 12-05-2009 03:13 PM
gas furnace vs 1 room electric heater Red Squirrel HVAC 11 10-17-2009 08:23 PM
Whirlpool Electric Heater No Power snick103 Appliances 1 04-10-2009 01:54 PM
Should i go from GAS to Total Electric HVAC & Water heater? ehoez HVAC 9 04-06-2009 08:57 AM
