Need Help With Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 10:48 PM   #1
Need help with Honeywell thermostat
Hi and hope someone can help me out ....
I have a 1h / 1c system ...
It has:
1. Honeywell PC8900a thermostat
- it has 4 terminals
#1 Red wire
#2 White wire
#3 Green wire
#4 Yellow wire
2. A W8900 Remote Module in the attic
Thermostat has a mind of its own and somewhat complicated + the wife hates it.
I would like to replace it and a friend of mine recommends a Pro1 - Model T905. It seems to be "friendlier"
http://www.pro1iaq.com/homeowner/thermostats_t905.html
My question and fears are that it will not be compatible with item #2 - W8900 Remote Module sitting in the attic for whatever it does.
So, my question is if its Ok to change it or do I have to go a different direction ?
I have called Honeywell and their only response is that I have to get their most expensive unit + change module also. My take on talking to them is they are only interested on selling me another product.
It used to be very easy to change thermostats in the old days but now things seem more complicated. The only extra I see in this unit is that it has an extra vent coming from outside for fresh air + it has an electronic open/close device on it. That is it.
Original home builder was Pioneer.
Thanks a million to anyone that can help me out.
mmspar is offline   Reply With Quote
Old 06-29-2010, 11:29 PM   #2
An old Tradesmen
Rewards Points: 6,074
The module should also be controlling your fresh air. That is a communicating thermostat.
It is a crappy thermostat though.
If you want a unit that still controls the fresh air intake. Get a Honeywell IAQ thermostat(YTH9421). Its also a communicating thermostat. But much friendlier.
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
