Need Help With Gas Furnance-FASCO INDUCER ASSEMBLY - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 09:48 AM   #1
Post
Need help with Gas Furnance-FASCO INDUCER ASSEMBLY
I have two gas furnaces and last week one stopped working. I checked the blower inducer assembly (motor was hot but no movement) and found some broken blades from the squirrel fan. I removed the broken blades and reinstall the inducer assembly, but still not heat. The gas furnce is made by Central service systems with a fasco inducer blower 7062-3136.
I have done everything I know of to fugure out the issue to no avail. When I turn the heat on, the fan works but no fire in the pilot. Any suggestions will be greatly appreciated.
Thanks,
Aziza007
Aziza007 is offline   Reply With Quote
Old 12-10-2010, 10:58 AM   #2
HVAC / Plumbing
check ps . Is ps closing ??
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
Aziza007 (12-10-2010)
Old 12-10-2010, 11:05 AM   #3
You mean the pressure sensor/switch? It opens and closes because I blew air into the vaccum line and I hear it click on and off. Otherwise, not sure what ps stands for.
Old 12-10-2010, 11:06 AM   #4
HVAC / Plumbing
Pressure switch. there should be a small rubber hose from ps to vent motor.. Never heard of central services systems furnace
Old 12-10-2010, 11:18 AM   #5
HVAC / Plumbing
ps requries suction to operate. suck on the hose & see if your furnace will start. If it does your not getting enough suction/vacuum to close the ps
Old 12-10-2010, 11:31 AM   #6
Rewards Points: 516
I found that the id fan is very delicate and engineered to provide proper suction only with all its blades.
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
Old 12-10-2010, 12:16 PM   #7
sounds like a pressure switch promblem. becareful when you blow and suck on it you can damage the diapharm on the inside. but if it is opning and closing it should be good the only real way to test it is with an manometer to see if it open and closes properly. and if your missing blades on your IDM replace that fisrt thatsw your promblem.
hvac kid is offline   Reply With Quote
The Following User Says Thank You to hvac kid For This Useful Post:
Old 12-10-2010, 12:49 PM   #8
Thank you all. Now assuming there not enough pressure/vaccum to operate the ps, what will be the corrective action short of changing the blower assembly? Thanks
Aziza
Old 12-10-2010, 01:12 PM   #9
aziza if your missing blades on your IDM you have to replace. or see if you can just get the squirell cage(blades) for it. the IDM removes all the carbon monoxide from your house without that it will leak into your home and make you sick or kill you. once that is fixed it should work unless you have other promblems.
Aziza007 (12-14-2010)
Old 12-10-2010, 01:13 PM   #10
is your IDM missing blades?
Old 12-10-2010, 01:38 PM   #11
Rewards Points: 516
Going here: http://www.fasco.com/xref_list.asp
punching in 7062-3136 under OEM nameplate, FASCO refers to as A168
Going here: http://www.fasco.com/fasco/pdf/p25.pdf, see specs for A168
maybe used to be A147? Also look carefully at pic and specs.
See also here for more match: http://www.fasco.com/fasco/pdf/p71.pdf
see more stats to match against your unit.
If you want to change just the blower wheel, see if your broken one has part # 8710-4358 stamped on back. If so, that's the SKU # at CSH Incorporated. When I ordered in September, part was $23.34 plus $7.80 to ship. 989-723-8985
Original link we/you used in appliance section will refer you to pics and text that are very helpful.
Fasco blower inducer 7062-3136 Aziza007 Appliances 1 12-10-2010 07:40 AM
Replacing Fasco 7062-3136 draft inducer blower on my Bryant Gas Furnace thalweg76 HVAC 0 02-20-2010 03:35 PM
Inducer assembly cracks and replacement/repair DIYNew HVAC 3 10-23-2009 01:55 PM
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 07:28 PM
Install Fasco Inducer Model A242 morrelld97 HVAC 1 10-03-2007 07:40 PM
