Need Help With Furnance. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 08:07 PM   #16
An old Tradesmen
Rewards Points: 8,184
First tab is fan off, second one is fan on, third one is the limit/burner off safety.
In the pic it looks like your on is 165, set it to 140. Also looks like your off is set to 50, try 110. Probably time for a new fan limit switch.
Old 12-03-2012, 10:37 PM   #17
Okay, so your fan works, that's good. You can leave it at the four minute start time, I don't see a problem with that, since there is a good chance that this was "adjusted" along with your other "repairs" as well.
rootboy is offline   Reply With Quote
Old 12-04-2012, 01:26 AM   #18
To be honest, I don't even know what the contractor that came out did with the wiring. The furnace was wired up wrong and they misdiagnosed it as a bad valve... Anyways... thank you for all the help. I'm happy to have a working heater.
I adjusted the fan limit switch. It turns the fan on about 2 minutes after the burners fire up, and cycles it on and off in about one minute intervals. The only way to get it to run for longer periods was to raise the 'fan on' tab to 160 degrees, but I'd rather not do that
k4ppa is offline   Reply With Quote
Old 12-04-2012, 04:22 AM   #19
An old Tradesmen
Blower may be wired to run at to high of a blower speed.
Old 02-16-2014, 12:14 PM   #20
does the transformer in a furnace control the fan motor turning on and off ?
ron2014 is offline   Reply With Quote
Old 02-16-2014, 12:18 PM   #21
Rewards Points: 150
I would run it at 160
hpyjack2013 is offline   Reply With Quote
Carrier furnance earl kay HVAC 2 01-14-2011 04:49 AM
Quatro Mba 080 NH2R furnance manual wolfden13 HVAC 1 02-10-2010 04:26 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 05:39 PM
Furnance question satz HVAC 8 02-05-2009 07:44 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
