Need Help With Furnace Install - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 02:53 PM   #1
I recently moved a new (one year old) York home furnace from one property to the other. I have the install mostly done but have encountered some issues. I am getting a trouble code of 4 red blinks, this says limit switch open, possibly dirty filter, improper ducting. My symptoms are as follows,
Turn thermostat on to heat with fan on auto, furnace doesn't start, if I push the safety switch on the furnace door, the furnace fires up, heats, runs, and turns off correctly. The exhaust blower continues to run no matter what position I use on the thermostat. Once the furnace is done running I have to again push the safety switch on furnace door to get it to fire again. My condensor for a/c sits directly on top of the furnace (this is the way it was with old furnace). I thought this was possibly not letting the correct amount of air pass? Any help would be great... it's getting cold in Wisconsin.
67Dart440GT is offline   Reply With Quote
Old 10-20-2011, 03:19 PM   #2
Now with removing some of my ductwork about the heating element I get the correct slow amber lights. But, I still have to keep turning the safety switch on and off to get the furnace to start again.... I am wondering if my duct work was too tight to the condensor not letting enough air flow out?
Old 10-20-2011, 03:35 PM   #3
And some more info now lol... Once the furnace stops it won't start again UNLESS.... I turn the power switch off then on... it will fire up and run normally. What gives?
Old 10-20-2011, 06:07 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
You need to remove the condenser from on top of the furnace and put it outside. Seriously.
Doc Holliday is offline   Reply With Quote
Old 10-20-2011, 06:15 PM   #5
Since it's a replacement how about some basic info. Gas pressure before and after gas valve in inches of water? Line voltage reads? When the furnace is on the air temp rise through the furnace is? Size and type of flue and how long? Furnace BTU's?
LOL Doc
Old 10-20-2011, 08:37 PM   #6
Sorry, I meant the evaporator.
Old 10-20-2011, 08:40 PM   #7
LOL Doc
Here is my unit.
http://www.fraser-johnston.ca/PDF/TG9SInstallManual.pdf
The flue is a pvc one I ran. The previous furnace used a metal flue that was piped up the chimney with the water heater flue. The length of the flue is probably about 15-17 feet in length as I had to relocate it's exit of the home.
Install Help on 75K BTU Garage NG Furnace live4spd HVAC 23 10-15-2011 07:58 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
