Need Help... Forced Hot Air Nightmare - Need Some Help Please - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 01:30 AM   #1
Need help... Forced hot air nightmare - need some help please
OK. So, we bought a home and it turns out the previous owner apparently did all of the HVAC work himself, and had NO idea what he was doing. We have an oil fed forced hot air furnace that's really only partially connected. Some rooms have 0 returns and 4 feeds, some rooms have 0 of both, some rooms just have feeds, and in our basement we found 1/2 of the feeds/returns were never connected for god no what's reason. So, as a temporary fix, we capped them but really need a long term solution.
A while ago, I saw this system that allowed you to convert a typical forced hot air furnace to a system that feed your rooms with a pex like tubing in lieue of traditional metal ductwork. Can anyone give me more information on this solution please?
mensrea is offline   Reply With Quote
Old 10-31-2011, 08:23 AM   #2
Rewards Points: 354
Don't know how easily you will be able to convert your existing equipment to a high velocity small duct system, but two of the main players in that segment are Unicool and Space Pak. You could google them and see if there is some adaptability or not.
HVACDave is offline   Reply With Quote
Old 10-31-2011, 08:45 AM   #3
biggles's Avatar
concentrate on getting one supply per room block the others remove the grill and install plasticon the back of the grill... so you pinch it back in...seal the connections with brush on sealer.do you have a hallway return grill? or are the returns in each room IT back to the furnace....did you have and engineers report during contract check this place or what?do you have AC there also...
Need help... Forced hot air nightmare - need some help please mensrea HVAC 0 10-31-2011 01:29 AM
fan forced joined with baseboard? DragonFire Electrical 2 12-28-2010 09:30 PM
Forced Air in 193 Year Old Home? jonathan03 HVAC 2 01-05-2009 08:47 PM
using forced air for radiant heating djsmith9 HVAC 22 10-30-2008 10:50 AM
Goodman GMP100-3 Forced Air Furnace Will Not Ignite Meerkat HVAC 4 02-05-2008 09:44 PM
