Need Help Finding Specific Capacitor! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 05:09 PM   #16
Originally Posted by mark2741 View Post
then my next step will be to order a replacement cap and when it arrives replace the universal cap with it. I want a spare anyway.
Does that sound sensible?
Why do you want to replace what looks like a high end Amrad turbo cap with a low quality generic 50/5 -370 which likely comes from China or Mexico?
As long as the tech. doesn't come back for his expensive turbo cap then leave it in.
P.S. Also, I would never use a 370V cap. Always upgrade to 440v. Capacitor quality is the biggest component problem in the HVAC industry.
hennyh is offline   Reply With Quote
Old 07-24-2010, 05:15 PM   #17
Because, once it was put in, the fan has run in reverse ever since.
It's not an Amrad - it's a motor-mate from motor-rundirect.com. Not that I think that makes any difference as I'm sure it's a decent quality cap.
mark2741 is offline   Reply With Quote
Old 07-24-2010, 05:33 PM   #18
Could just be a bad motor as was pointed out in post #3
Old 07-24-2010, 05:37 PM   #19
I don't think the cap is causing reverse running. If it's bad I'd think the unit wouldn't start.
If you have a multimeter then do a basic test of the cap.
Try and get the manufacturers wiring diagram and double check everything.
Old 07-25-2010, 08:31 AM   #20
Could be, but how can I ascertain that?
Old 07-25-2010, 09:11 AM   #21
Process of elimination. Move the fan wire on he capacitor to one of the other 5 spots. Double check the fan wiring if you have not already. If both of those are correct then all that's left is the motor.
Old 07-25-2010, 08:20 PM   #22
I understand that, but what I don't understand is why a motor going bad would run in reverse.
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 02:29 PM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 09:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 12:25 PM
problems with capacitor motor for pump joeypants Electrical 13 10-13-2009 04:18 PM
Maytag Plus Techman2006 Appliances 2 12-12-2007 11:40 AM
