Need Help With Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2008, 04:05 PM   #1
need help with duct work
i am installing a electric plenum heater there is an a coil in the plenum now. there is also insulation should this be removed before installing the plenum heater and why is there only insulation to the top of the plenum.
thanks
main concern is will the insulation catch fire with the electric heater
it is a 15kw
countrycpl is offline   Reply With Quote
Old 10-25-2008, 08:07 PM   #2
1610 CUB's Avatar
Rewards Points: 150
thanks
it is a 15kw
I have never seen an electric plenum heater. I've seen blower sections with electric motors, I've seen fan coils and blowers with coils, i have seen plenums with duct liner, or duct rap. The liner didn't burn I know nothing about the rap. Sorry about the limited knowledge..... j
1610 CUB is offline   Reply With Quote
Old 10-26-2008, 07:48 AM   #3
this is a lennox pulse 21 80,000 btu furnace with a a-coli for air cond installed i am installing an electric plenum heater to have duel fuel heat sorce the electric heater sits on top of the a coil just wondering if the insulation inside the plenum will cause a problem
Old 10-26-2008, 09:05 AM   #4
An old Tradesmen
Rewards Points: 6,140
It could.
Does your heater set up include a sail/air switch that must prove air flow before bring on the strip hreaters.
How much clearance are you going to have between the top of the A coil and the bottom of the strip heater.
If not enough, the strip section at the center of the A coil will over heat, and break from heat stress.
What are your gas and electric rates, all taxes, and delivery fee's included.
You must have very high gas rates, or extremely cheap electric, to make resistance heat cheaper then gas.
Old 10-26-2008, 09:23 AM   #5
we live in the country and the propane is our heat source and it is now at 2.50 gal electric is much cheaper at .5 per kilowatt there this heater is designed to be installe above the a-coil ther is aprox 5" clearance do you think that the black insulation is a problem inside the plenum or should it be removed. if your curioues about plenum heaters go to.www.electromn.com this system is set up as duel fuel so the plenum heater works just like the gas section but switches when no electric it uses gas
Old 10-26-2008, 09:50 AM   #6
An old Tradesmen
As long as it has operating limits, the insulation is not a problem.
Old 10-26-2008, 10:09 AM   #7
An old Tradesmen
5 cents is teh deliver electric rate?
All taxes and transmission fee's included?
If so, You should use a heat pump with electric aux for heat.
Need help Duct Sizing. Cyon HVAC 2 07-23-2008 09:15 PM
Tiger Foam On Duct Work atw58 Building & Construction 1 04-25-2008 11:25 PM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 02:43 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
duct sizing Stu HVAC 2 12-22-2006 06:36 PM
