Need Help Duct Sizing. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 06:17 PM   #1
Question
Need help Duct Sizing.
This is the first and last time I'll have to do this and I have no clue how. All I need is for these 2 forms to be filled out.
System 1 Form:
Constant Velocity Method
Please Size Duct Work Using Velocity Rate of:
Trunk @ 800, Branch @ 400, Return @ 600, Filter Grill @ 300FPM
Construction Data
Equip CFM 1200
| Duct ........ | CFM | Width | Length | FPM |
|A.) Unit
Supply
| B.) ......... | ___ |. (12") .| ______ | ___ |
| C.) ......... | ___ | _____ | ______ | ___ |
| D.) ......... | ___ | _____ | ______ | ___ |
| E.) ......... | ___ | _____ | ______ | ___ |
| F.) ......... | ___ | _____ | ______ | ___ |
| G.) ......... | ___ | _____ | ______ | ___ |
| H.) ......... | ___ | _____ | ______ | ___ |
| I.) .......... | ___ | _____ | ______ | ___ |
| J.) ........... | ___ | _____ | ______ | ___ |
All-Branches: | ___ | _____ | ______ | ___ |
Floor Reg: ... | ___ | _____ | ______ | ___ |
Return
K.) ............. | ___ | _____ | ______ | ___ |
Filter Gr .......| ___ | _____ | ______ | ___ |
System 2 Form:
Equal Friction Rate Method
Please Size Duct Work Using Equal Friction,
Ignore All Velocity Over Rides Except Filter Grill @ 300FPM
Construction Data
CFM ........................... (1500)
Avail Ext Pres Drop......... (.35)
Subtract;
Wet Coil ...................... (.09)
Filter Grill ..................... (.06)
Flr Register ................... (.03)
Heat Strip ..................... (.01)
Tot .............................. _____
Lgt Supply Run ............... _____
Plus Ret Run .................. _____
Tot Run ........................ _____
Conv to Friction Rate....... _____
|A.) Unit
Supply
| B.) ......... | ___ |. (14") .| ______ | ___ |
Return
L.) ............. | ___ | _____ | ______ | ___ |
M.) ............. | ___ | _____ | ______ | ___ |
N.) ............. | ___ | _____ | ______ | ___ |
O.) ............. | ___ | _____ | ______ | ___ |
Filter Gr ........| ___ | _____ | ______ | ___ |
Need help Duct Sizing.-system1layout.jpg   Need help Duct Sizing.-system2layout.jpg
Cyon is offline   Reply With Quote
Old 07-23-2008, 07:59 PM   #2
Rewards Points: 150
go to your local hvac supply house and by a ductulator
I would love to help but the slide chart will cost you like $3 and I hate paper work
geo fan is offline   Reply With Quote
Old 07-23-2008, 08:15 PM   #3
Here's some stuff to get you started.
http://www.designmaster.biz/Products/HVAC/LearnMore/Features/ductsize.html
http://www.engineeringtoolbox.com/equal-friction-method-d_1028.html
Searching this second website more thoroughly might turn up some constant velocity stuff.
The procedures look pretty tedious so I'd put them on a spreadsheet if you can.
ASHRAE is probably the ultimate authority on this but it's hard to get their books through interlibrary loan.
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 07:24 AM
duct sizing help dradaddy HVAC 2 01-24-2008 06:27 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 03:22 PM
duct sizing Stu HVAC 2 12-22-2006 05:36 PM
Duct sizing question Rob HVAC 1 06-04-2005 12:42 PM
