Need help Duct Sizing.
2 Attachment(s)
This is the first and last time I'll have to do this and I have no clue how. All I need is for these 2 forms to be filled out.
System 1 Form: Constant Velocity Method Please Size Duct Work Using Velocity Rate of: Trunk @ 800, Branch @ 400, Return @ 600, Filter Grill @ 300FPM Construction Data Equip CFM 1200 | Duct ........ | CFM | Width | Length | FPM | |A.) Unit Supply | B.) ......... | ___ |. (12") .| ______ | ___ | | C.) ......... | ___ | _____ | ______ | ___ | | D.) ......... | ___ | _____ | ______ | ___ | | E.) ......... | ___ | _____ | ______ | ___ | | F.) ......... | ___ | _____ | ______ | ___ | | G.) ......... | ___ | _____ | ______ | ___ | | H.) ......... | ___ | _____ | ______ | ___ | | I.) .......... | ___ | _____ | ______ | ___ | | J.) ........... | ___ | _____ | ______ | ___ | All-Branches: | ___ | _____ | ______ | ___ | Floor Reg: ... | ___ | _____ | ______ | ___ | Return K.) ............. | ___ | _____ | ______ | ___ | Filter Gr .......| ___ | _____ | ______ | ___ | System 2 Form: Equal Friction Rate Method Please Size Duct Work Using Equal Friction, Ignore All Velocity Over Rides Except Filter Grill @ 300FPM Construction Data CFM ........................... (1500) Avail Ext Pres Drop......... (.35) Subtract; Wet Coil ...................... (.09) Filter Grill ..................... (.06) Flr Register ................... (.03) Heat Strip ..................... (.01) Tot .............................. _____ Lgt Supply Run ............... _____ Plus Ret Run .................. _____ Tot Run ........................ _____ Conv to Friction Rate....... _____ | Duct ........ | CFM | Width | Length | FPM | |A.) Unit Supply | B.) ......... | ___ |. (14") .| ______ | ___ | | C.) ......... | ___ | _____ | ______ | ___ | | D.) ......... | ___ | _____ | ______ | ___ | | E.) ......... | ___ | _____ | ______ | ___ | | F.) ......... | ___ | _____ | ______ | ___ | | G.) ......... | ___ | _____ | ______ | ___ | | H.) ......... | ___ | _____ | ______ | ___ | | I.) .......... | ___ | _____ | ______ | ___ | | J.) ........... | ___ | _____ | ______ | ___ | All-Branches: | ___ | _____ | ______ | ___ | Floor Reg: ... | ___ | _____ | ______ | ___ | Return K.) ............. | ___ | _____ | ______ | ___ | L.) ............. | ___ | _____ | ______ | ___ | M.) ............. | ___ | _____ | ______ | ___ | N.) ............. | ___ | _____ | ______ | ___ | O.) ............. | ___ | _____ | ______ | ___ | Filter Gr ........| ___ | _____ | ______ | ___ | :thumbsup: |
go to your local hvac supply house and by a ductulator
I would love to help but the slide chart will cost you like $3 and I hate paper work |
Here's some stuff to get you started.
http://www.designmaster.biz/Products/HVAC/LearnMore/Features/ductsize.html http://www.engineeringtoolbox.com/equal-friction-method-d_1028.html Searching this second website more thoroughly might turn up some constant velocity stuff. The procedures look pretty tedious so I'd put them on a spreadsheet if you can. ASHRAE is probably the ultimate authority on this but it's hard to get their books through interlibrary loan. |
| All times are GMT -4. The time now is 10:33 AM. |
