Need Help With Ducane Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 07:27 PM   #1
Need help with Ducane unit
I have a Ducane condensing unit model HP12B30. The compressor and fan will not kick on. I thought it may have been the contractor relay so I replaced it. Even with the new relay, the unit still will not pull the contact poles down to kick on the fan and compressor. I can manually push the contact poles down and the unit will run but imediately kicks off when I release the contact poles. Any ideas?
bmeredith is offline   Reply With Quote
Old 07-22-2008, 09:26 PM   #2
biggles's Avatar
you need 24V out at the condenser that comes from the furnace/air handler TRANSFORMER thru the thermostat setting.quick test pull the stat cover and looking at the subbase jump R to Y1 that is your condenser contactor...if you can read voltage your meter should show 24Vs on the 2 THIN brown wrapped wires coming into the condenser.if you don't have it a wire might be broke on the run out was it working and it stopped suddenly?
Old 07-23-2008, 07:35 AM   #3
I will have to get a different tester. The one I have will not read that low.
The unit was working fine in the morning. I came home in the afternoon and noticed that the air it was producing was not cold.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
Radon Mitigation installed near AC Unit outside. Problem? majorchamp General DIY Discussions 16 06-30-2008 02:44 PM
Any Ideas? My AC Unit isn't coming on, inside or out? Signme001 HVAC 5 05-20-2008 10:14 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
