-   -   Need help with Ducane unit (http://www.diychatroom.com/f17/need-help-ducane-unit-24104/)
bmeredith 07-22-2008 06:27 PM
I have a Ducane condensing unit model HP12B30. The compressor and fan will not kick on. I thought it may have been the contractor relay so I replaced it. Even with the new relay, the unit still will not pull the contact poles down to kick on the fan and compressor. I can manually push the contact poles down and the unit will run but imediately kicks off when I release the contact poles. Any ideas?
biggles 07-22-2008 08:26 PM
you need 24V out at the condenser that comes from the furnace/air handler TRANSFORMER thru the thermostat setting.quick test pull the stat cover and looking at the subbase jump R to Y1 that is your condenser contactor...if you can read voltage your meter should show 24Vs on the 2 THIN brown wrapped wires coming into the condenser.if you don't have it a wire might be broke on the run out was it working and it stopped suddenly?:whistling2:
bmeredith 07-23-2008 06:35 AM
I will have to get a different tester. The one I have will not read that low.
The unit was working fine in the morning. I came home in the afternoon and noticed that the air it was producing was not cold.
