Need Help With A Ducane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 01:39 PM   #1
Need Help with a Ducane Furnace
I have a Ducane Furnace, model number CMPE075U3. the previous owner had it switched to propane. there are orifaces sitting next to the furnace, they say 42 on them. i wanted to know what size orifaces i need to switch back to natural gas, and how to change them. thank you
nwilson is offline   Reply With Quote
Old 11-27-2010, 02:36 PM   #2
http://www.andersonforrester.com/ori...s/default.html
Check this chart, may find what you need here.
SKIP4661 is offline   Reply With Quote
Old 11-27-2010, 02:56 PM   #3
Home Air Direct's Avatar
The parts breakdown for that unit shows a #7 Orifice/Disc (that is no longer available) for the natural gas models. I looked at the CMPE 075 spec sheets and it gives a part number 20272002 (Allied Air) as the LP to NG conversion kit.
Don't forget that just changing the orifices may not be the answer, as springs were probably part of the LP kit as well.
Good luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 11-27-2010, 03:02 PM   #4
HVAC Tech/Owner
Rewards Points: 604
Gas valve kits are also needed besides just orifices.
Technow is offline   Reply With Quote
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 04:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 06:44 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
