Old 06-25-2009, 06:51 PM   #1
Default Need Help With Condenser Motor Install
Hello Everyone,
Our condenser fan motor died recently and I've ordered a replacement motor but unsure how to do the wiring. The motor that died has three wires where as the new one has four wires. I have a wiring diagram that shows how to wire it for a three wire setup but still clueless as to how to wire them at the connecting points in the diagram.
Here is the diagram:
Your help is greatly appreciated.
Thank you!
fuemanchue is offline   Reply With Quote
Old 06-25-2009, 09:03 PM   #2
as seen on tv
power from load side of contactor 1 goes to capacitor orange from same side of cap as power purple on the unused side of cap the black wire to other power wire to reverse direction swap purple and brown as is in diagram
qbert is offline   Reply With Quote
Old 06-25-2009, 11:59 PM   #3
Thanks for the clarification!
Something I forgot to mention was that our AC system uses a dual round capacitor. I tried connecting the wires to the same locations as the old motor:
brown wire -> fan connector on capacitor
orange wire -> common connector on capacitor
black wire -> contactor
yellow wire -> purple wire
Motor didn't turn on at all. Hope I didn't fry it.
Old 06-26-2009, 12:05 AM   #4
as seen on tv
You will probably need separate capacitor if this is an multi horsepower replacement 3uf at 370v if incoming volts 240 7.5 if volts are 208
Old 06-26-2009, 12:18 AM   #5
Yoyizit's Avatar
The motor you ordered needs to be able to have a reasonably long service lifetime in an ambient temp. as high as 130F. The nameplate will have the temp. spec's.
Old 06-26-2009, 12:31 AM   #6
it's a 1/5hp motor replacing a 1/6hp motor.
More On This Topic
In this clip, were going to talk about the proper way to diagnose, remove, and replace a faulty windshield wiper motor. In this step, were going to talk about the proper service procedure in order to remove our wiper motor from the bulkhead. I have a ten... Read More »
In this clip we're going to talk about the proper way to diagnose, remove, and replace a faulty windshield wiper motor. In this step we're going to talk about the proper service procedure for reconnecting our wiper motor, hooking our battery up, and... Read More »
In this clip, were going to talk about the proper way to diagnose, remove, and replace a faulty windshield wiper motor. In this step, were going to talk about reconnecting of our wiper motor transmission to the ball stud. Now I've take and wiped all the... Read More »
In this clip, were going to talk about the proper way to diagnose, remove, and replace a faulty windshield wiper motor. In this step, were going to talk about the proper way to unplug and diagnose your vehicles windshield wiper motor. The wiper motor is... Read More »
In this clip, we're going to talk about the proper way to diagnosis, remove and replace a faulty windshield wiper motor. In this step, we're going to talk about the proper service procedure for installing our replacement wiper motor. You're going to want... Read More »
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 11:57 PM
Condenser Fan Stop/Start - Heat Pump mkurley HVAC 5 02-04-2009 04:06 PM
AC condenser install quote question amdspitfire HVAC 3 08-25-2008 11:56 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 08:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 01:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
