Need Help With Chimney Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 11:13 PM   #1
Need help with chimney flue
Newbie here with a question on concentric chimney flues. I finished my upstairs that was originally framed up but never sheetrocked. The chimney flue from a downstairs fireplace ran through an upstairs wall at an angle, but that wall wasn't framed all the way. When I sheetrocked, insulated, and ran electrical in the walls upstairs, I had to complete the framing of this wall so I removed the chimney flue. It was spring in south Louisiana so I just figured I'd put it back later. It's later now, and my wife wants me to put the flue back. problem is that I now have walls in the way where the flue used to go up to the chimney cap. I have tried to re-route the flue to no avail. I have called a fireplace installer and he said no straight run flues will work but doesn't deal with flexible flues. I have looked up flexible flues and found "liners" but not flues, and then again, I have no clue if I can use them. So, here is the question, are concentric flexible flues available, and are they safe?
Thanks in advance....Ray in South Louisiana
rwinsouthla is offline   Reply With Quote
Old 12-29-2010, 11:27 PM   #2
bump....anyone have an opinion?
Old 12-30-2010, 02:44 AM   #3
Check your fp manual, it will have all or nearly all the info that you need to vent your particular fp.
hvac benny is offline   Reply With Quote
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
gas hot water tank vent & chimney flue trees HVAC 11 10-16-2009 10:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
Chimney Flue Hole leezarrd Roofing/Siding 11 11-13-2007 05:18 PM
