Need Help "breaking" Thermostat! - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2006, 06:15 PM   #1
Need help "breaking" thermostat!
Hello everyone! I'm new to this forum and hoping that someone here can help me with a problem.
For a whole bunch of reasons that I won't disclose because I don't want to bore you guys, I want to tweak the thermostat attached to my central AC/heat system so that the air conditioning will NOT come on. I don't want to do anything to the heat or to the fan.
In other words, I need to "break" the thermostat if you catch my drift.
I removed the cover and saw a bunch of different colored wires and a circuit board but I really know nothing about HVAC .
I can tell you that the thermostat is a White Rogers model # 1F78 Non-Prgm.
So if anyone can tell me in layman's terms how to "break" my thermostat so that the AC will no longer work, I will be very grateful.
o2bjt is offline   Reply With Quote
Old 09-08-2006, 07:43 PM   #2
Furnace or heat pump?
If it's a furnace you can simply turn the central AC off at the disconnect out side near the unit or turn off the circuit breaker for the condensor unit.
If it's a heat pump you'll have to disconnect the wire that controls the AC, below are links for wiring the thermostat, with these you should be able to figure out which wire to disconnect.
Links to info and wiring for White-Rodgers 1F78 Thermostats
1F78-144 Non-Programmable, Horizontal
Installation and Operating Instructions
Supplemental Wiring
1F78H-144 Non-Programmable, Horizontal
Wiring and Configuration
mickeyco is offline   Reply With Quote
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 02:36 PM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 01:02 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
