Need Help With Aux Setting On Outside Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 11:00 AM   #1
Need help with aux setting on outside unit
I have a Trane heat pump, TWR060D100A1, Weathertron Heat Pump XE1000, with gas auxilliary backup. I want to adjust the outside temp sensor that communicates when the aux heat should come on and help the heat pump. I've removed the panel and see a knob that says C2 but I really have no idea if that's it or not, nor which way to turn it or see what it's currently set on. Any suggestions? It's cold here and I had our gas turned off for the summer, but got cold here before I thought it would so...want the heat to work at a lower temp without needing the aux.
Thank you.
tobysmom is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
