Old 01-24-2011, 10:06 PM   #1
Need help
I'm in the process of buying my first home but the inspector told I need more radiator for the room the house is 600 sq ft and it's 2 br 2 bath and eat in kitchen and dining the space is about 18x14 and one radiator the radiator is about 2 1/2 feet every room got one and there are two vents in too also Wat can cause the broiler to leak is it expensive to fix the house was oil and they changed it to gas and is it a problem if the floor is not insulated underneath it's a ranch style house
Gates is offline   Reply With Quote
Old 01-24-2011, 10:12 PM   #2
Need help
Help anyone!!
Old 01-25-2011, 03:46 AM   #3
An old Tradesmen
Need help
18X14=252
Doesn't take much to heat a small area like that.
Where is the boiler leaking?
If you insulate the floor, it will help you heat the house easier.
Old 01-25-2011, 08:43 AM   #4
Need help
This is s pic of the radiator an boiler where the leak is
Old 01-25-2011, 01:08 PM   #5
Need help
"one radiator the radiator is about 2 1/2 feet every room got one and there are two vents in too also"
So, is this a hot water heated house or hot air or both?
bob22 is offline   Reply With Quote
Old 01-25-2011, 01:16 PM   #6
Need help
Both heating system
Old 01-25-2011, 01:23 PM   #7
Need help
This is the broiler an there is a 40 gallon water heater
Old 01-25-2011, 08:19 PM   #8
Need help
Need advice
Old 01-25-2011, 08:46 PM   #9
WaldenL's Avatar
Need help
OK, so there are two questions here, yes? One about whether the radiator will heat that room and the second about the leak?
For the leak, can you get a better pic? Is it the valve that's leaking? Not a hard fix -- alternativly if you're buying this house, make the seller fix, or demand a price concession to have it fixed.
For the radiator, why is the inspector worried? Was the room cold? Radiator hot? 18x14 isn't huge, one rad might be fine. Or it could be a very drafty room and feel cold. But in that case, solving the drafts is better than another radiator.
More details are in order here.
WaldenL is offline   Reply With Quote
Old 01-25-2011, 10:17 PM   #10
Need help
He is saying it's going to take long to heat up because the floor underneath is not insulated.
Old 01-26-2011, 05:13 AM   #11
An old Tradesmen
Need help
Take a better pic of where the leak. But from here. It looks like its just time to replace the sight glass and its seals. Not hard to do.
Its a boiler, not broiler.
Insulate the floor under the room/house. That will save you money on your heating bill. Your inspector, is giving you REAL BAD advise telling you to add another radiator. You get a lot of heat from steam, so it won't take long to get that room warm with that radiator.
Old 01-26-2011, 08:26 AM   #12
Need help
What the best insulation to use for the floor .
Old 01-26-2011, 02:18 PM   #13
WaldenL's Avatar
Need help
How much money you got? :-)
Money not an issue, spray foam it. You'll seal drafts and insulate. Of course, back in reality, stuff some batt insulation up there and be happy.
Old 01-26-2011, 05:15 PM   #14
hvaclover's Avatar
Need help
Need advice
I think somebody stole the periods from your first post.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-26-2011, 07:03 PM   #15
Need help
Hvaclover: I think somebody stole the periods from your first post.
Excellent! LOL!
