Old 12-31-2005, 09:16 AM   #1
Question
Need HELP!!
I have a forced air furnace(gas). It has been working fine until yesterday. THe call for heat ignites the pilot but the burners do not ignite. Since it is New Year's Eve I would like to be able to fix this myself, as I cannot wait until Wednesday for the repairman. Any ideas?
ironman17 is offline   Reply With Quote
Old 12-31-2005, 11:29 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Need HELP!!
Natural gas or propane (check tank...may have just enough for pilot, not enough for burners).
Hopefully, an HVAC pro will come along soon and help you.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-31-2005, 04:55 PM   #3
Question
Need HELP!!
I appreciate the answer, but I should have been clearer. The source is not propane but gas from Dominion. The furnace is a Carrier if that makes a difference. I already replaced the thermostat, no help. Any other ideas?
Old 12-31-2005, 08:41 PM   #4
Need HELP!!
Look for any reset buttons. I just reset one when a window fan caused a down draft telling the gas to shut off. That would be all my knowledge on the subject.
K2eoj is offline   Reply With Quote
Old 01-07-2006, 12:11 PM   #5
weinstall.ca
Post
Need HELP!!
Most likely gas valve if it is intermitten.
weinstall.ca
allan is offline   Reply With Quote
