Old 02-11-2007, 09:28 PM   #1
need heat suggestion for lower level
we own a split level with heat pump/central air
most of the vents are for the upstairs.
when we bought the house only one register was downstairs. i added another register to the downstairs so now there are 2 vents downstairs but it is still chilly.
i have the thermostat upstairs.
i was thinking of adding an electric baseboard(downstairs) with a separate thermostat that will be placed downstairs.
is this a good idea and what would i need to do this job
please help
dallison is offline   Reply With Quote
Old 02-12-2007, 10:57 AM   #2
Baseboard heat runs on a 220v. You would need to make sure you have enough room on your electric panel to add a 220v. If you do you could install one or more than one baseboard heaters in the area. The nice thing about basements is that they stay a constant temperature due to them being underground. Are the registers not heating? Make sure all walls and ceilings are insulated. Most likely a basement will always be slightly cooler because cold air sinks.
cibula11 is offline   Reply With Quote
Old 02-12-2007, 12:02 PM   #3
no basement. split level on a slab.
after ripping the paneling off to expose the drywall, everything is pretty well insulated, i added a little where i felt the cool air.
there are only 2 registers that are downstairs so it stays cooler.
so the other inexpensive addition would be the baseboard. i can drill the holes for the wire and do the install and have the electrician wire it into the box
Old 02-12-2007, 12:07 PM   #4
i think we have 200 amp service si i think i may be able to use it. it won't be used that often
Old 02-12-2007, 12:20 PM   #5
How big is the area you want heated? That will depend on how many baseboard units you will need.
Just an FYI. I am converting an attic space and considered baseboard heaters for a time. My biggest problem is that I didn't have enough room on my panel and didn't want to mess with electric work as it would be quite costly. I called my HVAC guy and am waiting for a quote. He thought to run a duct and some other stuff to the attic would be about $400. And the positive is that I will also get AC in the room too. With baseboard you only get heat. I might have some quotes done before you decide. Running more ductwork into the area might be cheaper.
Old 02-12-2007, 12:20 PM   #6
concretemasonry's Avatar
Your heat supply does little good if you do not have plenty of returns - more area than supply.
Running your fan constantly when heating, will improve the confort and uniformity tremendously. If you have a good variable speed fan, the cost will be minimal and will actually reduce you cooling costs by removing more moisture.
I have a similar split level situation with the lower level having poorly insulated walls, an open stairway and a big sliding door in Minnesota. In the winter I have a 1-2 degree maximum difference from upstairs to downstairs at a central location. My exterior walls are cooler (digital readings) because of a shortage of insulation.
concretemasonry is offline   Reply With Quote
Old 02-20-2007, 07:54 PM   #7
the downstairs is cool in the summertime.
the area downstairs is about 600 sq ft.
the downstairs has drop ceilings and the ductwork is contained there.
the area where i would install the baseboard is on the floor to the right of the panel.
i have the wire, so i will run it to the box and have an electrician wire it up
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 11:01 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
