Need Heat B4 Winter - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 10:32 AM   #1
Wheels
Need heat b4 winter
Had an Aquatherm water heater that supplied hot water for domestic use and water coil (in air handler) for heat. Last November I installed a instant water heater for the domestic water and tried a regular water heater (tank) for the hot water coil in air handler for the house heat. Instant water heater works well but the regular 55 gal water heater would not keep up. Could not keep house at 72 degrees when weather would go below freezing. Water heater can only supply 160 degree water, dont think thats hot enough? Now I'm thinking about putting a boiler to supply hot water coil in air handler. Any idea or suggestions???????? Thanks
cweiles is offline   Reply With Quote
Old 09-04-2009, 05:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
You have less than 40,000 BTU's with your water heater and lots of it goes up the chimney so it is way too small. Do you still have the old Aquatherm to get the BTU rating off it? How are your electricity costs per kwhour. There are small electric boilers available and they can be wall mounted.
Old 09-04-2009, 06:51 PM   #3
Hey Yuri, sell 'im an atomic powered boiler.
hvaclover is offline   Reply With Quote
Old 09-05-2009, 06:11 PM   #4
HVAC / Plumbing
I tried one of those hydro heat systems years ago...It couldn't keep up... Swaped it out for a 90+
kenmac is offline   Reply With Quote
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
