Need Flange For 7 Inch Chimney Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 06:48 PM   #1
need flange for 7 inch chimney pipe
I'm removing a wood burning fireplace and the chimney runs out the back of my house and on up. I have removed the chimney but the hole through the wall is a little rough and a bit larger than the 7 inch diameter. What i thought might be a solution would be to get a 7 inch cap with a flange that has a 2 inch or so lip on it that would cover the hole in the wall. If that does work where might I find a flange like that? What do you guys think? Any suggestions are welcomed.Thanks.
beech is offline   Reply With Quote
Old 12-08-2012, 08:07 PM   #2
Rewards Points: 13,732
Got a picture.
What's on the outside and inside walls that's preventing you from fixing it right instead of just plugging the hole.
Old 12-08-2012, 08:33 PM   #3
I'll post a picture tomorrow. What do you mean fix it right I thought plugging it was the correct fix. Thanks for your help.
Old 12-08-2012, 08:49 PM   #4
Since there is no picture we have to guess. From your description all I can picture is a hole in the inside and outside wall with no insulation in the hole.
How was the outside wall fixed where the chimmney was?
Is this just a sheetrock wall, plaster, paneling?
What I'm trying to suggest is instead of having to look a plug sticking out of the wall why not just patch it so the whole wall looks the same.
Old 12-08-2012, 08:51 PM   #5
Thanks again. The wall I'm talking about is the outside brick wall.
Old 12-09-2012, 04:21 AM   #6
An old Tradesmen
Rewards Points: 7,362
I believe the right way would be to brick it shut.
Old 12-09-2012, 06:15 AM   #7
Rewards Points: 1,216
Fill the hole in with insulation or expansion foam then finish the interior and exterior the the same as the existing.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-09-2012, 08:34 AM   #8
Ok thanks for all your help.
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
closet flange for cast iron pipe tomknox Plumbing 26 01-21-2012 11:05 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 07:09 AM
4 inch drain pipe econdave Building & Construction 7 06-04-2009 11:57 AM
