Old 09-19-2012, 12:05 PM   #1
Need to find a new capacitor
So I'm about to move into a house, but part of the deal is that it comes as is (it's a great deal, trust me). So I check the AC, doesn't kick on, check the outside unit, and it has no capacitor. Really, none. Stolen? I've changed capacitors before at a maintenance gig, but we were always provided with a standard unit to switch out.
Can you guys help me find a capacitor that will work if I post the unit's specs? I'm not sure what's important, so I'm basically going to post the top half of the service panel:
Model: CK24-1B
Serial #: 9410038199
AC Volts: 208/230
Phase: 1
Hz: 60
Voltage range: 197-253
Min circuit amps: 16.4
Max fuse amps: 25
Any help is greatly appreciated, even just an idea of what to look out for. Thanks guys.
-Beau
BeauMan is offline   Reply With Quote
Old 09-19-2012, 01:06 PM   #2
JJboy's Avatar
http://www.google.com/url?sa=t&rct=j...3vKu9g&cad=rja
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
BeauMan (09-19-2012)
Old 09-19-2012, 03:26 PM   #3
Perfect. Thanks for leading me to a great resource.
Heat pump not working! Tested capacitor! MikeVila HVAC 28 01-11-2012 05:01 PM
Run Capacitor Failed regularguy Electrical 6 01-06-2012 06:36 PM
Air Compressor Capacitor Question tlwright6 Electrical 3 10-19-2011 12:04 PM
capacitor problem cpowell243 Electrical 6 10-11-2011 10:58 PM
Find the Right Contractor for Two Home Improvement Projects mdawson3k General Discussion 10 05-16-2011 03:34 PM
